0 Members and 50 Guests are viewing this topic.
Aerotower
#19095
Can you add the last helicopter delivered to FAP (Portuguese Air Force),
SN           HEX   Code REGISTO   TIPO AERONAVE   OBS.
14965      497CB3  29703   AW119                   Delivered 03/10/2019
Thanks,
Manuel
yang
yang
781799 is in the d/b as an A359, see attached
Thanks Manuel, that's it in
Michel
Alan,
AFR1062 LFPG-ESSA
AFR11VP EDDH-LFRS
AFR145L LFPG-ESGG
AFR1793 EHAM-LFRS
AFR47SC LFPG-EKCH
AFR48NN EKCH-LFPG
AFR88ZA LFRS-EDDH
AFR79ZP EHAM-LFLC
AFR97UD LFPG-EDDH
AUA379 LOWW-EHAM
BEE4CR EHAM-EGBB
BEE4MN EHAM-EGBB
BEE7YB EGCC-EDDL
BEE74D EDDL-EGCC
BMS2955 LRBC-EIDW
BMS6XZ EGGW-LRIA
CFG8AD LEPA-EDDH
DLH1A EHAM-EDDF
DLH2KV EGCC-EDDF
DLH7ET EDDF-EHAM
DLH7HT EDDF-EIDW
DLH8JC EDDF-EHAM
DLH8MM EDDM-EHAM
GIA089 EHAM-WIMM-WADD
IBE32ML LEMD-EDDH
IBE32SD EDDH-LEMD
IBE33DK LEMD-ESSA
IBK5083 EKBI-LEMG
KLM1381 EHAM-LIRN
KLM19K EHAM-ESSA
KLM23W EHAM-LIMC
KLM24L ESGG-EHAM
KLM25B EHAM-EDDT
KLM27G EHAM-EDDV
KLM68Y EDDT-EHAM
KLM70G ESSA-EHAM
LCO1509 EBBR-EKCH-SBKP
PGT14R EHAM-LTFJ
PGT37K EGSS-LTFJ
PGT50F LTFJ-EGSS
PGT62K LTFJ-EHAM
QTR9VZ EHAM-OTHH
ROT362Q EHAM-LROP
STK3GC EHGG-EGMC
THY1PB LTFM-EHAM
THY5DC LTFM-EGCC
VLG582G EKCH-LFPG
Michel
CarlosAbreu
01-11-2019 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Michel
Alan,
AFR134M EHAM-LFPG
BEE87F EHAM-EGLC
DLH2FN EHAM-EDDM
DLH5CF EDDF-KBOS
KLM19K EHAM-ESSA
KLM25X EHAM-EDDL
KLM91J EHAM-EDDS
PGT11Q LTFJ-EGCC
QTR9UF OTHH-EHAM
STK3GC EHGG-EGMC
THY1DL EGCC-LFTM
Michel
X
#19103
762 squits on this one,  VP-BOP Airbus A321-251NX Ural msn 8955 on delivery
* 43BE8D  SVR372   UMKK-UUDD                                             2019/11/02 14:05:48
X
X
A friend in Bulgaria keeps picking up two unknowns which are very regular, 456038 and 45603B. From the DB it looks like the numbers he gives are in a batch of Bulgarian ground signals.
X
Thanks X, yes they look like ground vehicles
Northern Watch
Good afternoon Alan
Just been cleaning up mylog and noticed the following that did not populate:
38515C / low level only 10 message counts
3C4B22 / 32,000 ft only 6 message counts
401AEA/ G-BBMB / DR40
A1D093 / 40,000 ft only 16 message counts
AE6820 / eyeball as a Boeing 737 believe this to be a Poseidon and not long after AE6833 which looked similar.
Hope I haven't given you to much of a headache sorting these few out.
Best regards
Keith
Hi Keith
38515C doesn't decode
3C4B22 decodes to D-ABYB, last use on a Lufthansa 747 which crashed in Nairobi 1970
401AEA,G-BBMB,848,Robin DR 400/180 Regent,N Clark & K Wade
A1D093,N216HZ,1147,Gulfstream Aerospace G-IV,Newport Executive Transportation
AE6820 & AE6833 both US Navy P8 Poseidons, they have taken to using tactical codes during October on some flights
No problem to sort out, either have the info or I don't
