0 Members and 13 Guests are viewing this topic.
CarlosAbreu
#19380
16-12-2019 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
X
Alan/ffa
New unknown unallocated ex somewhere in Pskov region heading in direction of Rostov at 35000ft. Full ADSB. No doubt another Russian Military miscoder.
* 0004DB  XE8                                                         2019/12/17 07:28:25
X
Hi Terry
Greenshill Capital are  the finance company owning the aircraft but they are operated by Sozo Aviation per Eurocontrol
X
#19384
Finally after months VP-BZY has shown up SVO ex ISL and should be ex PK-LFR B737-9GPER 35719/2694
* 42439C  KARVPBZY                                                       2019/12/17 17:29:12
X
It is as you details X.  No idea what your miscode could be either
CarlosAbreu
17-12-2019 Updated file in attach.
Carlos
AirMe
NPT071M is an alt callsign for 3V71
NPT072L is an alt callsign for 3V72
Thanks AirMe, they route EBLG-LIRA-EBLG
AirMe
#19390
T7117 callsign is ITI117 (sometimes ITI117A) MRS-TUN
T7118 callsign is ITI118 (sometimes ITI118A) TUN-MRS
EY49 callsign is ETD88U AUH-BCN
AirMe
Quote from: romdouk on December 18, 2019, 04:14:29 PM
F-HBLM/N/O: Hop! (as opposed to HOP!)
Acutally HOP (ICAO code) is called and operates as Air France Hop since September.
Thanks AirMe  ITI is a new code, now added to the database as is Intairline.  What aircraft do they use?
#19393
HOP is no longer used as flight ID, all flights use AFR flight ID's
Per Wikipedia https://en.wikipedia.org/wiki/Air_France_Hop
In February 2019, Air France announced that HOP! services will be rebranded as "Air France Hop".[8] A first aircraft received the revised livery - being the one of Air France with small HOP! titles added - in May 2019.[9]
On September 1st, 2019, all HOP! flights were moved under Air France code. The aircraft will be gradually repainted into the Air France Hop livery.[5]
AirMe
Quote from: Runway 31 on December 18, 2019, 04:22:06 PM
They use Spanish Swiftair (SWT) ATR42s. But T7 is Twin Jet (TJT) IATA code, Intairline don't have a IATA code.
Also Ryanair's Malta Air (MAY) new aircraft flies with 4D2238 hex, not in db.
VOE15SC is the callsign for V71561 NAP-PMO
