0 Members and 67 Guests are viewing this topic.
Michel
Alan,
AEA972 EFRO-LEMD
AUI108 EGKK-UKBB
IBE32BD EDDH-LEMD
IBE32PG LEMD-EDDH
NVR148 GCFV-EKCH
NVR152 GCLP-EKBI
TRA5561 EHAM-EPKT
Michel
Thanks again Terry
Ignore Trustees for NetJets
CarlosAbreu
06-01-2020 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Hi Terry
Keeping simply as Pilatus as per the many other Swiss registered ones in the d/b
F-HKRA staying as Pegase per the French register
Staying with Plane Fun Inc Tr Trustee per the other couple of hundred in the d/b
An interesting article here about the murky world of aircraft trustees https://apps.bostonglobe.com/spotlight/secrets-in-the-sky/series/part-one/  with the one above mentioned in it
CarlosAbreu
07-01-2020 Updated flight in attach.
Carlos
X
* 781694        2020/01/08 19:18:20
Probably  you got on departure but it did not register with me
X
No idea X, not aware of any deliveries today, nothing on Skyliner or the XFW blog.  Pity there was not flight ID associated
400M23R
781694 is B-108R P28A PA-28-181 2881056 Sichuan Longhao Flight Driving Training Company
Graham
X
#19527
Graham/Alan
Thanks for the info on B-108R but it is a long way from home for a PA28 to be around Moscow.  At 35000ft and at night it is not B-108R, so must be something else miscoding B-108R's hex. Probably a poor signal from 781696 B-308C A359 as it was around at the same time.
X
Thanks for the info on the Archer Graham.  Yes looks like a corrupt packed X, no flight id is symptomatic of that
Hi Terry
N682GD is showing on FAA as having a pending number change to N888ZF and I picked it up last night using this so N682GD was deleted and the new registration added.
Going by their website ProAir are now PROAIR so standardised on that https://www.proair-aviation.com/
