All gone, thanks again Terry
CWB
0AC431
HK-4696
B06
Bell 206B JetRanger III
2509
Delta Helicopteros
ex-N96BH
The correct one would be E492D0
424465 (Using wrong code since it was delivered)
PR-YYI
A20N
Airbus A320-251N
7514
Azul Linhas Aereas
ex-PR-OBI Avianca
Thanks CWB  The JetRanger is already in the database
Many thanks Terry, all gone
CWB
#19729
Correct
0AC436
HK-2752-G
C82S
Cessna T182 Turbo Skylane
18267879
Serial number: 18267xxx = T182 Turbo Skylane
In all the sources that I looked at they have the wrong data.
Ex; JetPhotos, Airplane Pictures, Planespotters, FR24, Airliners...
http://www.aerocivil.gov.co/consulta-en-linea/consulta-de-matriculas-de-aeronaves
#19730
Hi CWB
HK-2752-G is a Cessna T182 and as you can see in your attached shot taken from the register is detailed as ICAO C182 on it
T182 all have an msn beginning 182***** ICAO C182
Four-seat light aircraft with fixed landing gear, powered by a turbocharged 235 hp (175 kW) Lycoming 0-540-L3C5D, piston engine, gross weight of 3,100 lb (1,406 kg) for take-off and 2,950 lb (1,338 kg) for landing. Certified on 15 August 1980
T182T Skylane all have an msn beginning T182*****  ICAO C82S
Four-seat light aircraft with fixed landing gear, powered by a turbocharged and fuel-injected 235 hp (175 kW) Lycoming TIO-540-AK1A piston engine, gross weight of 3,100 lb (1,406 kg) for take-off and 2,950 lb (1,338 kg) for landing. Certified on 23 February 2001
Thanks again Terry, all gone
hunter2021
0AC3D4
PNC-0242
ATR 42-320
380
PolicĂ­a Nacional de Colombia
X
#19735
ffa
   A2DBA2  RA2831G                  N2831G     CH7B  S W & L K Johnston   2020/02/05 17:38:47
Miscoding A2DBA2 c/s RA2831G flew from Yaroslavl to Novinki-Begicheva airfield 50km SSW of Moscow DME at 10,000ft at up to 195knots, an approximate distance of 350km. Other than the "Rainbow" quote for RA-2831G from Russianplanes.net, I wonder if you can confirm the actual type.
X
X
No I only have Rainbow from the Russian register
CWB
Correct
0AC9B0
HK-4628-G
B60T
Beech B60 Royal Turbine Duke
Thanks Terry, those re-registrations are hard to spot on the V6 software
