0 Members and 282 Guests are viewing this topic.
CWB
#19830
Correct
48C131
SP-RKS (Not SP-RKD)
48C123>SP-RKD
Many thanks
#19831
Hi CWB
48C131 is in the database as SP-RKS was added in yesterday .  It was myself that noted it on its first flight out of STN as RYR753
48C123 was added to the database as SP-RKD 22/11/2019 and is operating RYR77CF as such at this time, see attached
Are you seeing them different somewhere?
CWB
#19832
Quote from: Runway 31 on February 16, 2020, 06:42:05 PM
Hi CWB
48C131 Showing how SP-RKD I saw other people commenting on it in Europe as well.
Update: In the search SP-RKS it appears that nothing was found.
CarlosAbreu
16-02-2020 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
#19834
Hi CWB
Yes I see on its flight history SP-RKD has one flight, RYR753 showing as 48C131 all the other flights for it are showing as the correct 48C123
I can only assume there was a glitch on the RB24 system which showed the incorrect hex code
The aircraft was an unknown when it took off from Stansted so should have had no aircraft details then.  I noted it taking off and raised a query on the mode-s forum at 1503 and received a reply at 1510 advising it was SP-RKS and the c/n was unknown at the time subsequently advised at 1604 that it was 44704 ex EI-FIS and the details were entered into the database
As stated SP-RKD was added to the database 22/11/19 so can only concluded that the RB24 server got itself confused somehow
I cannot see that SP-RKS has made any further flights since
Database entries for both aircraft showing the date and time of last change attached for reference.
Thanks for bring to my attention
CWB
hunter2021
0AC98B
HK-5340
B190
UE-106
SEARCA
CarlosAbreu
17-02-2020 Updated file in attach.
Carlos
X
#19841
You can remove IL76's UR-CMC and UR-CRP from the DB. Both were damaged beyond repair on the ground in Libya last year
X
X
New ground vehicle at SVO is 115FA0 RA90016 (no hyphen)
X
hunter2021
A11340
EJC1134
C208
Cessna 208B Grand Caravan
208B-2140
Ejercito Nacional de Colombia
Thanks X
I dont apply registrations to ground vehicles, marked as GND only
