0 Members and 17 Guests are viewing this topic.
mikek
AE52A8, G08826, should be CH-47F, 09-08826.
Cheers,
Mike
#20073
Thanks Mike
BTW The system gives your location as Auckland but is showing your flights from Florida.  I see you picking up a P8 tac code this time AE687C
CarlosAbreu
19-03-2020 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
X
#20075
This routed Ivanovo to Kursk at 28000ft
* 1D33F5    78837                                                             2020/03/20 08:39:31
1533F5 decodes to RA-78837 however 1D33F5 ought to be RF-78837 IL76MD-M Russia Air Force c/n 10034 01024 based at Ivanovo
X
mikek
Hopefully it has updated to Jacksonville now if I found the right spot to change it.
I have had another of the last batch of T-6s which also fits in with them being four out of sequence between the Callsign and what the database has them listed as.
I now have:
AE58E8, RN243, but in database as 168247
AE58F7, TXN258 but in database as 168262
AE58F9, SH260 but in database as 168264.
So I am pretty sure that unless they are all transmitting their callsign wrong by 4 numbers, they need to be updated, at least between AE58E8 and AE58F9.
Thanks again!
Mike
CarlosAbreu
20-03-2020 Updated file in attach.
Carlos
#20081
Hi Mike
The AE58E* and AE58F* were updated 16/3 after your previous post so looks like you could do with doing an update
The ones you mention are in as follows
AE58E8,166243,PN-234,Beech T-6B Texan II,US - Navy,
AE58F7,166258,PN-249,Beech T-6B Texan II,US - Navy
AE58F9,166260,PN-251,Beech T-6B Texan II,US - Navy
Hi Terry
0D0AE3 has been in the d/b since June 2018 with RedWings as the operator
Its also in as a miscode using 406AE1
hunter2021
0AC955
HK-5325
AT76
ATR 72-600
1172
