0 Members and 22 Guests are viewing this topic.
I have nothing on it X
X
#20208
Thanks for your information and a query regarding it
What was your information source for the tie up and any ideas why a Comoros registered aircraft would be in the Moscow area.  As you detail it with a Lithuanian hex code do you have any information on it moving their register or is it going to the factory for maintenance
D6-NOA has used 035043 as its hex code and it was previously OK-SLP and PR-NOA before becoming D6-NOA in 2015.
It may be the case as on checking CH Aviation I find that D6-NOA in no longer in the fleet of Int'Air Iles, they operate a sole Saab 340 so it is possibly re-registered
I also note that hex code 503CA0 was noted flying in Khazakstan today using flight ID UP-CS018 which would indicate that it is a Cessna type https://www.radarbox.com/data/flights/upcs018
My database shows 503CA0 as LY-BCF this was a Cessna 172S Skyhawk SP c/n 172S10319 of Aerojet Baltic which operated from Requena Airport in Spain which as far as I am aware was subsequently sold to Russia as RA-67429
Alan,
Can't help any further I'm afraid, only going by what is quoted on the Blackswan website.
This website however is also giving the same information :
https://opensky-network.org/aircraft-database/
X
#20211
UP-CS018 is a Cessna 172 according to this article
Jan 5, 2018 - ... воздушные суда Cessna-172 с регистрационными номерами UP-CS018 и UP-CS019, принадлежащие ТОО "Training center Part FCL"
On this date 5/1/18 the two were reported damaged by heavy wind at Chimkent, and must have been repaired.
X
X
The one I picked up is the one in your radarbox attachment but it is in Russian airspace over Nizhny Novgorod not that far from Moscow.
X
OK thanks X see that now, still showing as UP-CS0018 as its flight ID and was cruising around FL80 and around 120 knots whereas a Let l-410 would cruise at over FL200 and up to 250 knots
CarlosAbreu
07-04-2020 Updated file in attach.
Please correct the following entry of 06-04-2020 file:
RCH244 LERT-KVPS instead of LERT-KNGU
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
X
Another miscode it is now RA-2917G
   393C28  RA2917G                  F-GPBI     P32R  Polyconsult Inter... 2020/04/08 17:35:15
X
Thanks Carlos
RCH flights don't get added to the database
CarlosAbreu
No problem this database file is my daily control, please just use data you need, ignore the others.
Anyaway how can I update ANRB database without changing my manual entries ?
Checked option "Do not update manually changed records" works fine in this enviroment ?
I'm going to make a backup of my database and try it soon.
Carlos
Carlos
Make sure that your manual entries are marked N instead of Y
Also suggest that you keep a copy of your Navdata before you update just in case things don't work as you suggest
