1 Member and 57 Guests are viewing this topic.
X
You have 155C34 hex for RA-89140 in db already but under Aeroflot not Red Wings.
X
Thanks X I meant any hex for the non RA- registration or is it the same
X
#21167
It is the same hex the RA- is just covered with tape, the frame may have used a Sukhoi test hex prior to that but we know they are in a batch of 97001 thru 97020 and used multiple times
As it used c/s I suggest you put the 'Lithuanian' hex miscode against UP-CS018 until we discover otherwise
X
Thanks X.  I added the code to UP-CS018 yesterday
mikek
A couple of updates:
AE08B5 is listed as F/A-18 165926. This should be T-6A 165960 which fits in with the sequence of other T-6s
AE1156 listed as 165596. It should be 165996
Thanks!
Mike
CarlosAbreu
08-10-2020 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
X
Seems Red Wings are taking delivery of a few Su-95's This is RA-89138 and is not in DB
* 155C32  RWZ9991                                                        2020/10/08 20:07:01
X
X
* 151D48  AZV8883                                                        2020/10/09 08:39:24
151D48 decodes to RA-73032, reregistered B763 VQ-BSY Azur Air 27614/661
X
X
I have this Russian hex at 36000ft at 400 knots in test area SE of ZIA
* 1D2B01        2020/10/09 11:42:03
I think that this should be be 152B01 which decodes to RA-76545 and therefore is most probably RF-76545 IL-76MD Air Force on test.
X
X
* 150697        2020/10/09 12:13:32
150697 decodes to RA-67223 which is/was a CL30 of Severstal c/n 20172. Any reason why it is not in DB?
X
Thanks Mike.  regarding AE08B5 I only have databases to go to so an eyeball is perfect
X
Noted RWZ9991 out of ZIA last night and added it in.  It was initially using 144**
Caught RA-73032 over Turkey this morning inbound Antalya and added it in
RA-67223 became D-BOOM in 2018 hence the reason it was deleted from the d/b
I have deleted 152B01 from the database and replaced it with 1D2B01
X
#21178
So do we have a RA-67223(2) or has D-BOOM (which is a regular here) gone back to RA-67223? D-BOOM was at VKO in September
X
hungryasthesea
Alan,
A couple flying this morning and not in database today:
407098 - G-BRCD - Cessna A152 Aerobat
and
4179F2  - G-JOET - Aeropro EuroFox
David
Hungryasthesea
