0 Members and 29 Guests are viewing this topic.
Carlos
You have detailed that ET-EUR and SE-DYM are not in the database and give both the same hex code 4A932D.  Both are in the database correctly 4A932D belongs to SE-DYM and ET-AUR as 040143
CarlosAbreu
Thanks it was a mistake in copy past file.
I must update my database, the problem is that I have thousands of data manually inserted and if I do it I will lose them.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
#21437
Just click on Do not update manually changed records.  Save a copy of your existing Navdata first just to be sure.
CarlosAbreu
I saw that option but inside database there's another one that says "AUTOUPDATE" that is marked "Y" by default.
My doubt is if in all data that I manually inserted they must be marked with a "N" in order to not be changed.
Carlos
#21439
OK, if you are worried maybe better not to.  If you manually add/change a record you should update to N to prevent it being changed by an update.  Also you need to untick Auto Update Manually Changed records in File/Preferences/Radarbox/Photo and aircraft auto-populate
You could tick Auto-populate Aircraft data in File/Preferences/Radarbox/Photo and Aircraft Auto-populate or click on unknowns if you see them on screen and the information will download
CarlosAbreu
Thanks I will check it.
Carlos
CarlosAbreu
#21441
29-11-2020 Updated file in attach.
Carlos
AoD
Hi Alan
company update:
49D261, OK-PVN, Gumárny Zubří a.s.
49D0D4, OK-HFL, Aerovia z.s.
49D11A, OK-XIG, Aerovia z.s.
Michel
Alan,
AFR10MD LFPG-EKCH
AFR1051 EKCH-LFPG
BOX192 EDDP-EGNX
BOX463 KIAH-ENZV-EDDF
CHH466 EGLL-ZHHH
CKS254 EDDP-EGNX-KCVG
CSN5232 EGSS-ZGGG
CSN8148 EGLL-ZGGG
CXA8687 ZSAM-EHAM
CXA8688 EHAM-ZSAM
KLM1818 EDDB-EHAM
KLM37J EHAM-LEBL
Michel
hunter2021
Error aircrat IAI 1125 Astra
0D8303
YV3045
BE20
Beech B200 Super King Air
S/N ??????
Private Owner
CarlosAbreu
30-11-2020 Updated file in attach.
Carlos
X
#21449
All photographed at ULY yesterday
155C35 RA-89141  SU95 Red Wings new c/s 95201
155C36 RA-89142  SU95 Rossiya Airlines      95202
155C37 RA-89143  SU95 Red Wings new c/s 95203
155C38 RA-89144  SU95 Red Wings new c/s 95204
X
