0 Members and 51 Guests are viewing this topic.
CWB
AD0E23
N940LA
Socata TBM-940
LAAS Data (is wrong in the database)
CarlosAbreu
29-01-2021 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Thanks CWB amended to 940
X
Alan/ffa
   1552A0        2021/01/30 12:04:05
1552A0 decodes to RA-86688 which was an Il-62 that was broken up 20 years ago. This is third time in three months I have picked it up and there is absolutely nothing else it could be around it. Probably a false code but is annoying and always only a couple of squits each time.
X
Yes looks like a corrupt packet X
CWB
Hi, Alan
Below is a list of Brazilian airports that have undergone changes in the IATA and ICAO codes, attached:
Many thanks
CarlosAbreu
30-01-2021 Updated file in attach.
Carlos
Thanks CWB, I will have a look and make any necessary amendments
CWB
Hi, Alan
Some details that were left without updating.
VDC - SBVC  Glauber de Andrade Rocha Airport
QSC - SDSC Mário Pereira Lopes Airport
UBT - SDUB Gastão Madeira Airport
GGH - SSCT Engenheiro Gastão de Mesquita Filho Airport
CAU - SNRU Oscar Laranjeira Airport  (At IATA, the name "Laranjeiras" is wrong, right is Laranjeira ")
TOW - SBTD Luiz Dalcanale Filho Airport (At IATA, the name "dal canalle" is wrong, right is Dalcanalle ")
Many thanks
#21776
Thanks CWB, apart from SSC which I must have missed, as I couldnt cut from your sheet the rest were cut and paste from Wiki
CWB
I crossed data with IATA, DECEA and Infraero to get this information, the Wiki is not reliable, even at IATA I found errors ... thank you for the update
Michel
Alan,
ABD366 EDDF-KORD
ABW524 EHAM-ENGM-UUEE
ABW9389 OMDB-EHAM-EDDF
ABW9391 OMDB-EHAM-LEMD
AUI2206 MDLR-UKBB
AZG4220 EHAM-UBBB
BAW12 WSSS-EGLL
BAW981 EDDB-EGLL
BCS207 EDDP-EGNX
BCS2881 EIDW-EDDP
BOX383 KCVG-EDDP
CCA646 EGLL-ZSPD
CSC3780 EBBR-ZUCK
CXA8701 ZSAM-EGLL
KLM47Y EHAM-EDDN
KLM52Q LIMF-EHAM
KLM81N EHAM-EDDB
QTR8562 OTHH-EGLL
UAE2564 EHAM-OMDB
UAE9747 HKJK-EHAM
UAE9749 HKJK-EHAM
Michel
