0 Members and 14 Guests are viewing this topic.
X
Last 24 hrs
ABW286  EBLG-UUEE-ZHCC?
CHH787  ZJHK-LFPG
KAR9406  UUEE-LFOK
NWS064  UWWW-UMKK
NWS180  USCC-UUEE
NWS366  UWGG-UMKK
NWS924  UKFF-UUEE
PBD1167  UUWW-URMM
SDM4529  UUEE-EVRA
TUP6408  USSS-EDDF
TYA9455  ULLI-UUDD
VAS9601  UUWW-UOOO
VAS9602 UOOO-UUWW
VAS9621  UUWW-UEEE
AZV5016  UTST-UUWW
X
Thanks X, I note 2 or 3 of those have been used on different routing in the last week or so
X
#22413
I started noting that too, especially on the ad hoc freight flights, some seem to go from/to China for example via SVO/DME to MAD returning via LGG and return. Damned confusing!
141CC8 with c/s RA07403 for Robinson R66 c/n 1007 is approaching MOW but in DB as R44 RA-07368. Strange one this as RA-07403 ought to be 141CEB!
141CC8  RA07403                  RA-07368   R44                        2021/04/28 13:05:20
141CC8  RA07403                  RA-07368   R44                        2021/04/28 14:16:15
X
X
141CC8 RA-07368 R44 Raven I c/n 2483
141CEB RA-07403 R66 c/n 1007
Both correct so looks like a miscode and I will leave them in the database with the correct tie-ups
Hi Alan
Correction - The Scaled Composites White Knight Two N348MS ICAO code should be WHK2, not WHKN. I can't find a code for the 318 White Knight, N318SL, but apparently it isn't WHKN.
#22416
Hi Rod
Correct WHK2 for N348MS and N318SL should be coded ZZZZ.  It looks like WHKN was correct around 2013 but it would appear to have been deleted at some stage I assume because N318SL was retired from flying in 2014.
Although it is still on the FAA list as it has been retired for 7 years and its certificate is due to retire soon I have deleted it from the database
CarlosAbreu
28-04-2021 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
X
Yesterdays flights
ABW252  EBLG-UUEE
ABW9900  UUEE-VGHS
AFL1100  UUEE-URKK
AFL7302  UUEE-LSZH
AUL263  UUDD-URMO
AZV8401  UUWW-URSS
CAO1070  EBLG-ZSCN
CHH487  ZGSZ-LFPG  route change
NWS 2021  UUEE-LDPL
PBD161  UUWW-URKK
RSY8831  UUWW-UTNU
RWZ107  UUDD-ULLI  route change
RWZ108  ULLI-UUDD
SBI2632  UNBG-UUDD
SBI3046  UIAA-UUDD
SVR7036  LCLK-ULLI
SYL4732  UEEE-UUWW
TUP6588  EVRA-UUEE-UNKL?
X
Hi Alan - ICAO typo spotted:
42461E VP-BSR is in as an A20M instead of anA20N
Thanks Rod, thought I had caught it but obviously not
CarlosAbreu
29-04-2021 Updated file in attach.
Carlos
