0 Members and 22 Guests are viewing this topic.
Michel
Alan,
AZG209 UBBB-EHAM
BAW985 EDDB-EGLL
EJU35EL EHAM-LEIB
MPH7342 SEQM-KMIA-EHAM
TFL273 EHAM-LGKO
TFL694 GCLP-EHAM
THY82E EHAM-LTFJ
TRA4Y EHAM-LIPX
TRA5680 LEIB-EHAM
TRA40H LIBD-EHAM
UPS225 KSDF-EDDK
Michel
Hi Alan
4B008E needs your attention. It's in as ATR 72-202F HB-AFN with ICAO  A772. HB-AFN is now EI-SLT with a hex of 4B008F and a type of ATR 72-201F. The ICAO should probably be AT72. I'm confused but I'm sure you can sort it out.
CarlosAbreu
24-05-2021 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Its sorted Rod, thanks for bringing it to my attention
CarlosAbreu
25-05-2021 Updated file in attach.
Carlos
hungryasthesea
Alan,
When you have a moment could you have a look at the following and correct if necessary
Mode S - 4079F8 in database as C-FRNS, I belive it should be G-FRNS
and
Mode S - 3007D1 in database as I-SAGR, I belive it should be I-SAGE
David
Hungryasthesea
Correct on both counts David, thanks
CarlosAbreu
26-05-2021 Updated file in attach.
Carlos
