0 Members and 111 Guests are viewing this topic.
CYYZGUY
40" LED Monitor
40" LED Monitor
as it hasn't populated can you re-check this one: 3D158B,D-EGKH,168,SOCATA TB10 Tobago please?
Thanks!
As far as  I can see its OK Ingo, it evens has a photo attached now.
Thanks Alan,
either I get it with the auto-populate during next reception or my monthly db download update.
Michel
Alan,
RYR23Y ESGG-LFOB
BTI6E8 EBBR-EVRA
Michel.
#2346
Evening Alan,
SAS4657 : ENZV-LEAL
NAX1703 : LELC-ENGM
DAH2676 : DAAG-LEBB
TRA52J : EHRD-LEAL
TRA6148 : LEAL-EHAM
AoD
TVS1073   LYPG - LKPR
GWI5568   EDDT - LTAU
IRA720   EDDF - LKPR - OIIE (regular refueling in Prague)
CYYZGUY
#2348
40" LED Monitor
40" LED Monitor
Morning Alan, unknowns from Saturday:
31FF15  DEUMC http://www.vafc.at/flugzeuge/tecnam-p2002-jf-d-eumc/ Maybe the airframe is using the hex that was temporary applied during a repair at the manufacturer in italy.
3D0F94  DEEDO https://planefinder.net/data/aircraft/D-EEDO Mk1EB in 2015 / picture in Flugzeugforum.de
3D201D  DEKKJ https://planefinder.net/data/aircraft/D-EKKJ
3D31AD nothing more
3EDB35  DKXYZ http://www.rcawsey.co.uk/Ven2cm.htm and http://www.onlinecontest.org/olc-2.0/gliding/flightinfo.html;jsessionid=9ABD7FD83F2D1247A1DFD103BAD6D811?dsId=4345472
3F027D  D8678 no 100% reliable information found
3FF17D  DMCCX  FK-14 Polaris Eyeballed October 2014
3FF1E3 D-MOPV http://www.flugzeug-bild.de/bild/flugplaetze~deutschland~tannheim-edmt/61437/privat-d-mopv-fk-leichtflugzeuge-fk-9-mk-iii-23082013.html
3FF2ED  DMBRE http://www.flugzeugbilder.de/show.php?id=1370560
3FF3E1  DMAAV http://flugsport-locktow.de/home/Marktplatz/UL1.htm http://www.flugzeugbilder.de/show.php?id=1374760
424112 nothing more
4403E6 OE-VCM http://www.amateurflugzeugbau.at/Projekte/Lancair.html
478374 was LN-WDA now RP-C3033 no indications of a new airframe using this REG/HEX
505D1C nothing more
Have a nice Sunday!
As a Thunderstorm was passing by in the morning and dumping lots of water and hail we will get another great day with high temperature and humidity...
Regards Ingo
#2354
Morning Alan,
EI-EKR B737 c/n 38503 of Ryanair is no longer miscoding but is correctly using 4CA819.
MON672M : EGCC-LEAL
