1 Member and 26 Guests are viewing this topic.
Good Afternoon! Unknowns from Monday:
340445 nothing more
3C0C0C nothing more
3C4875 nothing more
3C650A nothing more
451C63 http://www.planespotters.net/Aviation_Photos/photo.show?id=073608
453070 nothing more
770584 nothing more
7807BF nothing more
A4E7CD decodes N415MG but is not assigned/reserved by FAA
US MIL: AE16F5  WARHAWK1 http://forum.scramble.nl/viewtopic.php?p=783780
MILs
* 3E871D  GAF640                                                         2015/08/31 10:38:56
* 3E871D  GAF640                                                         2015/08/31 12:44:42
* 3EAECF        2015/08/31 11:39:29
Regards Ingo
Sunday:
31FF15 I-PDVF I guess the miscoded from D-EUMC again
344586  ECMAK (two times) http://www.flightradar24.com/data/airplanes/ec-mak/ and http://www.ballooning.nu/index.php/item/coupe-aeronautique-gordon-bennett-2015
387DDB  FPALL http://www.gordonbennett2012.ch/de-teams.html
3C09F5 nothing more
3D158B  DEGKH is in db but does not populate via auto-populate or manual populate (db download update next WE)
3D1C8D  DEJBH https://planefinder.net/data/aircraft/D-EJBH and http://www.planespotters.net/Aviation_Photos/photo.show?id=563007
3FF17D  DMCCX received again, no new about details
3FF2A5  DMOCZ nothing new to report
3FF2D6  DMMSE same as above
444064 nothing more
45AA5E nothing more
46C82C nothing more
4841D4 nothing more
48A231  AMQ1 http://www.flightradar24.com/data/airplanes/sp-iss/
48A5D0 nothing more
4911DA was and maybe is CS-DNZ http://www.flightradar24.com/data/airplanes/cs-dnz/
49D192 was OK-CCA now EW-366PA nothig about a new one with this REG/HEX
4CAA18 nothing more
505CDC nothing more
71BC30 nothing more
Regards Ingo
orkney
Hello Ingo
I should get on to these tonight too and I will let you know when they are done
Andrew
CYYZGUY
Somewhat of an oddity here for me.
Mode-S 4242BB
Flight ID: LGT1
Coming up as `Hong Kong Airlines Management``
Flightaware reports it as ``Longtail Aviation``
Can you see what is correct..
Jason
40" LED Monitor
40" LED Monitor
orkney
Hello X
That is your Turkey routes done apart from
MNB123
BUC967
THY5730
ABG7724
THY5912
BUR102
ROT6112
ROT6114
Ingo, I will get yours done tomorrow.
Andrew
diddyboy
Hi Alan
A couple of Unknowns yesterday from Djibouti.
* 04C152        2015/09/02 11:01:47
* 04C152        2015/09/02 15:29:47
   662FF5        2015/09/02 02:57:37  (This could possibly be one of the drones that are in the region)
Also one route amendment
EY959 is now OMDW - HDAM on day 4 and not OMSJ - HDAM
Neil
orkney
Hello Ingo and Neil
Ingo, All your known ones are added. Neil, I cannot find anything for that two yet but I have amended that route.
Many thanks
Andrew
Afternoon Andrew,
AFR1055 : DAAG-LFPG
WZZ261 : LEAL-LHBP
Unknown hex : 320019
No further information.
orkney
Hello Ian
That is that two routes done and I can't find anything for that hex
Andrew
Good Afternoon, Evening! Unknowns from Wednesday:
3001A3 nothing more
3D6A11  DFMKN https://planefinder.net/data/aircraft/D-FMKN
3D7A71  DFSPT https://www.facebook.com/permalink.php?id=196699400376090&story_fbid=908593732519983&_fb_noscript=1  and http://www.flugzeugforum.de/threads/79989-Flugbetrieb-in-Neubrandenburg-Trollenhagen-2015/page13?p=2190849
3D84B1  DFWMV https://planefinder.net/data/aircraft/D-FWMV http://forum.luftfahrtclubbraunschweig.de/05-11-2013-flug-werk-fw-190-d-fwmv-1-take-off-bwe-t3458.html
3E5D2A  DKAMC SF 25 C Falke Mk1EB 2015: http://www.flugzeugforum.de/threads/70529-Flugbetrieb-in-Borkenberge-EDLB/page38?p=2187665#post2187665
3FEF34  DMOTB http://www.daec.de/fileadmin/user_upload/files/2012/luftsportgeraete_buero/kennblaetter/105-12.pdf
47A362 nothing more
48A4C2  SPKGC http://www.flightradar24.com/data/airplanes/sp-kgc/
4A910B nothing more
501E2E  9ATOB http://www.flightradar24.com/data/airplanes/9a-tob/
80A691 nothing more
E403CD nothing more
regards Ingo
MILs:
   3F4605  GAF120                                                         2015/09/02 11:17:30
   3F63C4        2015/09/02 11:42:27
* 3F76A1  PACK32                                                         2015/09/02 12:09:33
orkney
Hello Ingo
That is all your known ones done.
Thanks once again
Andrew
AoD
Hi Alan
route:
NAX4EL   LEBL - EPWA
WZZ479   LBBG - EGGW
company:
710022, HZ-MS4C   Saudi Armed Forces Medical Services
48B68C, SP-NWM   Press Glass
43E840, M-MARI   Rumit Aviation Ltd
43EA2D, M-YVVF   Lightstar Aviation Limited
orkney
Hello Aod
Thanks form them. They are all done.
Andrew
#2399
Any ideas on this one - 4067C3, using FlightID GEWEN000, in the Inverness area.  Presumably piloting a flying carpet!
