0 Members and 47 Guests are viewing this topic.
X
Pinging on ground at SVO
151D8F  RA-73103 B737-8LJ  41231/6259 Aeroflot Russian Airlines ex VP-BMB
X
X
#24166
Overnight non populators
* 151D85  AFL1482  UUEE-UNKL  RA-73093  B738        2022/03/21 01:13:11
* 151DE1  IZA302    UUDD-USII   RA-73185  B738        2022/03/21 08:53:07
* 151E62  NWS183   UUEE-URMM RA-73314   ????        2022/03/21 07:39:51
X
X
151D85 RA-73093 B738 inbound to you shortly on AFL1483 ex VP-BCD
151DE1 RA-73185 B738 40242/3540
151E62 RA-73314 B738 40233/2952 on its way back at this time
I have DRU9941 out of VKO this time unknown 151E34 RA-73268
X
Thanks I have just seen 151E34 RA-73268 depart.
I have already seen over 30 re-registered aircraft only about 870 to go :(
X
X
On ground at SVO
151DAA RA-73130 B777-3M0ER   41688/1175 Aeroflot Russian Airlines ex VQ-BQC
X
Thank X, saw it pinging
X
151E09 pinging out of VKO is RA-73225 B738 Pobeda
X
X
RA-73225 B738 64862/7107
X
* 140629        2022/03/21 09:28:41
* 140629        2022/03/21 14:41:58
140629 decodes to RA-01577 and according to LAAS is a Pilatus PC‑24 c/n 240
X
Both were noted and added in X.  For info 140629 was using PCH240 as its flight ID
AlSo added an Aeroflot A321 noted pinging on the ground at SVO
Alan,
PCH is the ICAO code for Pilatus.
X
Your getting too good at beating me to it with new and reregistering a/c. I just saw the A321 you mentioned RA-73166 depart SVO. The weather is great for spotting here just now :)
X
Hi Alan
Could you look at 407A7E? it's a Grob G-109B with the reg in as G108 G-Cmrh and wrong photos.
Thanks Ian, yes it was using its Pilatus test flight ID.  The PCH flight ID usually correspond with the c/n
Thanks Rod, a wee bit of brain fade
I have blacklisted the photos, you will need to delete them from your photo folder
