0 Members and 87 Guests are viewing this topic.
Michel
Alan,
AFR13ZJ EHAM-LFPG
AFR14HZ EHAM-LFRS
AFR17DW EHAM-LFPG
AFR59HK LFPG-ESSA
AFR76WQ EHAM-LFML
BAW813C EKCH-EGLL
BAW814L EGLL-EKCH
BAW991 EDDB-EGLL
BLA5ZA LROP-EHAM
CFG1LP EDDH-GCRR
DLH1AN EHAM-EDDM
DLH3V EHAM-KDTW
DLH4EU EDDF-EIDW
DLH7A EHAM-EDDF
DLH8EK EGCC-EDDF
EIN3ER EDDB-EIDW
EIN53W EDDM-EIDW
EIN6NL LOWW-EIDW
EJU71YG LKPR-EHAM
EZY19FG EDDB-EGKK
EZY87KL EDDB-EGCC
EZY94NE EGPH-EDDB
EZY97XZ EDDH-EGKK
KLM58D LOWW-EHAM
NOZ5333 ENBR-LEAL
NSZ4251 ESSA-LEBL
PGT36H LTFJ-EHAM
PGT50A EGSS-LTAI
SXS35G EHAM-LTAU
TAP786 LPPT-ESSA
TAP562 LPPT-EDDH
THY22J LTFJ-EHAM
THY6TA LTFM-EHAM
TVF39RP EHAM-LFPO
VLG2MQ LIRQ-EHAM
VLG2TF EHAM-LIRF
VLG3TV EHAM-LEBL
VLG5M EKCH-LEBL
VLG68XG EHAM-LEAL
VLG969E ENGM-LEBL
Michel
X
I believe RA-67160 is something like a GLEX (it has the range of Vladivostok to Moscow, a CRJ does not). I watched the play back and both aircraft were apparently sat at UUEE at the same time as 150658 landed at 03:30 and never departed and RA-67240 arrived from ULWC  at 09:00. The only explanation would be the pilot turned of its transponder to return to ULWC (but I do not think that would happen). I believe that they are two different aircraft.
X
If you are correct either then they have a new one as they dont have a GLEX in the fleet only CRJ and SU95.  Unusual for them to have a biz jet I would have thought
It was Russian forums that were detailing the miscode
X
The reason I do believe they are different aircraft is that both Flightaware and FR24 state 150658 SSF9552 flew direct from Vladivostok to Moscow last night which is a distance of approx 6500 km and is well outside the range of a CRJ. The range RA-67XXX tend to be where most Bombardier/Canadair aircraft lie in which I think why a GLEX is a possiblity. Possibly it is a loaned and recently re-registered aircraft and you are correct that too date Severstal fleet is only CRJ and SU95 types. Time will tell.
X
M
QTR31K   OTHH   EFHK
GCR7981   ZHCC   EBBR
GCR7982   EBBR   ZHCC
AZD87   ESNN   ESSA
AFR95YX   LFPG   EFHK
AFR23EJ   EFHK   LFPG
FIN47G   LIPE   EFHK
FIN1AM   EFHK   LTAI
FIN1DP   LTAI   EFHK
BRX255   ESNU   ESSB
BRX258L   ESSB   ESNU
BRX261   ESNU   ESSB
BRX262   ESSB   ESNU
BRX263   ESNU   ESSB
NSZ4009   ESSA   ESNU
NSZ4010   ESNU   ESSA
NSZ2902   EFHK   LEBL
NSZ2903   LEBL   EFHK
NSZ2522   EFHK   EFRO
NSZ2523   EFRO   EFHK
NSZ2TH   EFHK   LFMN
NSZ8YC   LFMN   EFHK
NSZ2514   EFHK   EFOU
BTI7WE   EETN   EBBR
NYX420   EFKE-EFKK-EFHK
NYX421   EFHK-EFKE-EFHK
NYX425   EFHK-EFKE-EFHK
NYX426   EFHK-EFKE-EFHK
NYX427   EFHK-EFKE-EFHK
NYX429   EFHK-EFKK-EFKE
TAY4867   EBLG-EFHK-EETN
CarlosAbreu
01-04-2022 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
X
The overnight non populators
* 152073                                     RA-73843                          2022/04/01 23:20:50
* 151FC0  SBI2508  UNNT-UUDD   RA-73664                          2022/04/01 12:21:33
* 151FD5  RSY9537  UUWW-ZGHA RA-73685  A33X                 2022/04/01 10:08:44
    152044  SVR2878  UTDK-ULLI     RA-73796  A32X                2022/04/01 10:10:29
* 151DDC  AFL1332  UUEE-ULAA    RA-73180  A320  7240       2022/04/02 08:58:49
X
X
151FC0  RA-73664 B738
151DDC RA-73180 I caught it on departure from ARH so it should populate when you pick it up inbound SVO
X
Just got 151DDC (RA-73180) back on screen but is not populating however should tomorrow morning when I do my next DB download
X
I should have populated if clicked on
X
I clicked on the hex and reg areas three times each and it still did not populate. I do not know why but has always been that way. I already have 'Auto populate data' switched on, maybe its the version I use.
X
