0 Members and 15 Guests are viewing this topic.
Michel
Looks like TRA has shuffled their callsigns again....
TRA65X  EHAM-GCLA iso EHAM-LIPX
TRA661 EHAM-GCLP
TRA88G EHAM-GCTS
TRA3A LGSM-EHAM iso EHAM-LPPT
TRA4U EDDT-EHRD iso EHAM-LGIR
Michel.
#2446
Morning Alan,
it seems, that you forgot to do my Sunday unknowns in reply #2438. Well, on the other hand it seems, that you did them, but forgot to tell me, that you did them.
Regards Ingo
X
   3B9BCE   FNY5118
   683231    UPEM017 arr sandpit last night, call sign possibly a giveaway as UP-EM017 suggests an Embraer??
X
X
#2448
Well back to only a couple of unknowns, the Saudi no doubt a Haj flight from OEJN to the East somewhere
AIC926   OERK-VIDP    VT-ALH     B77L  Air India            2015/09/07 20:17:09
SVA4114                    TF-AMV     B744  Air Atlanta Icela... 2015/09/07 01:54:53
X
Morning Alan,
Now that you have probably finished all the routes for THY and Pegasus, I have one easyJet for you to give you something to do :
EZY65VE : EGKK-LEAL
Looks like I forgot to advise you Ingo or at least press the send button as I remember writing the post.  Yes it was done.
Thanks Michel, as far as I can see they shuffle them every 6 weeks
Thanks again X.  However can find nothing on those unknowns.  The FNY looks like it is an Atlantique
The Kazak is likely to be an Embraer as you suggest but its unknown to me at this time.
falcon_nl
Unknown: 3C17DB, AIB768A (So it must be a plane from Airbus Industrie)
Hi Alan, unknowns from Monday:
falcon_nl: 3C17DB should be D-AYAW another A321 Test REG of Airbus
1C4D28 nothing more
* 3C17D8  AIB763A                                                        2015/09/07 08:10:48
* 3C17D8        2015/09/07 10:10:27
D-AYAT A321 Test Reg http://xfw-spotter.blogspot.de/2015/09/a321-231sl-capital-airlines-d-ayat-b.html
* 3C17DA  AIB767A                                                        2015/09/07 10:39:06
* 3C17DA  AIB767A                                                        2015/09/07 12:08:31
D-AYAV A321 Test Reg http://xfw-spotter.blogspot.de/2015/09/a321-231sl-avianca-d-ayav-n744av-msn.html
451F1C nothing more
48A4C2  SPKGC http://www.flightradar24.com/data/airplanes/sp-kgc/
4CA896 nothing more
4CA943 was EI-ERT now VQ-BOB
4CAA29 was EI-EWS now VN-A557
MILs:
* 3E8433        2015/09/07 07:11:20
* 3E8433        2015/09/07 08:33:15
* 3E875F  GAF910                                                         2015/09/07 07:55:54
* 3E875F  GAF910                                                         2015/09/07 09:58:20
* 3EADA6        2015/09/07 09:16:49
* 3EB810  GAF087                                                         2015/09/07 06:45:51
* 3EB810  GAF087                                                         2015/09/07 10:07:03
* 3F44DC  GAF139                                                         2015/09/07 08:16:24
* 3F44DC  GAF139                                                         2015/09/07 10:57:59
* 3F51AF  GAF767                                                         2015/09/07 11:05:39
* 3F51AF  GAF767                                                         2015/09/07 14:15:02
* 3F6A5A  GAF723                                                         2015/09/07 07:23:57
Regards Ingo
falcon,
3C17DB,D-AYAW,VARIOUS,Various Airbus A321 Airframes,Airbus Test Registration
falcon_nl
Good evening Ingo,
3C17D8,D-AYAT,VARIOUS,Various Airbus A321 Airframes,Airbus Test Registration
3C17DA,D-AYAV,VARIOUS,Various Airbus A321 Airframes,Airbus Test Registration
48A4C2 SP-KGC already in the d/b
Nothing on the others and mil tac added
this MIL hasn't populated:
Please confirm, that it is in the db. Thanks!
