1 Member and 108 Guests are viewing this topic.
Michel
Alan,
AFR16CJ LFPG-EDDH
AFR33RU LFPG-EKCH
AFR35AJ EKCH-LFPG
AFR69PB LFPG-EDDH
CAI82EP EHAM-LTAI
CAI82FT LTAI-EHAM
CND125 EHAM-LICT
EJU16EA LICC-EHAM
EJU7895 EHAM-LEPA
EJU7932 EKCH-EHAM
EWG9P LEMG-EDDH
EZS46DG EHAM-LFSB
EZY16UZ EHAM-EGCC
EZY48DP EKCH-EGKK
EZY74RN EHAM-EGGW
EZY96PU EHAM-EGGD
KLM30Q EPWA-EHAM
KLM36F ENGM-EHAM
NSZ3515 EGKK-EKCH
PGT60E EGCC-LTAI
TFL3JH EHAM-LTAI
THY1MD EHAM-LTAI
THY3KJ LTAI-EHAM
TOM9GH EGCC-HESH
Michel
Thanks X
152021 I believe is an A320 as you suggest
152037 c/n 1247
CarlosAbreu
17-04-2022 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
X
This is definitely a second box issue on RA-73112 as on arrival it had 608 squits on the below miscode and it just departed UUEE using the correct code 151D98
* 141D98  AFL1481  UNKL-UUEE                                             2022/04/18 06:38:14
X
X
#24501
Looks like we might be nearly at half of the changes to Russian fleets so far. Aeroflot is slow to tie up however they at least have names on the aircraft which helps when photos come through. S7 is proving very difficult and I have not noticed any Red Wings A320/1 fleet changes yet.
X
Noted X, miscode applied
X
* 152015  AFL1364  UUEE-URMT                                             2022/04/18 12:55:29
152015 is RA-73749 A320
X
Thanks X, noted it out of SVO
Michel
Alan,
AFR1250 LFPG-EKCH
CFG5FP GCTS-EDDH
CND121 EHAM-LEIB
EJU31XF LDSP-EHAM
EZY14XP EGGD-EKCH
IBE30VD EKCH-LEMD
Michel
Northern Watch
Good evening Alan
One from earlier today not populating:
A3336C / Callsign N305RR / 34,000 feet.
Keith
CarlosAbreu
18-04-2022 Updated file in attach.
Carlos
