0 Members and 42 Guests are viewing this topic.
I posted the error regarding Niagara Helicopters.
Thanks Ingo from one grouchy old man, didn't sleep well last night.  Once again my apologies to Jason, suitably embarrassed now
The things you were thinking but not writing were about  your fingers  not typing in what supposed to be typed in or about me because you considered my message to be too impolite?
I will leave things as they are Ingo I have commented more than enough.
Just out of Seville as RRR4511 43C5DF ZM405 Airbus A400M Atlas c/n 024
falcon_nl
#2495
Unknowns:
3C5EC1, LXG55A flying now near Dusseldorf
3FF419, DMERE
3D2E1C, DEPYN
And a new one: 4851ED, PH-MOD, 1145, P208, Tecnam P2008 JC
falcon,
3C5EC1, LXG55A decodes to D-AGVA unknown to me
3FF419, DMERE unknown to me
3D2E1C, DEPYN - 3D2E1C decodes to D-EPSE,919,Lake LA-4-200 Buccaneer however that does not correspond with the flight ID given.   D-EPYN is unknown to me but should be 3D2EC1 so looks like it is a miscode given the flight ID.
Good Afternoon, the unknowns from Wednesday:
006300 nothing more
1C4C15 nothing more
3C0A06 nothing more
3C0FE2 nothing more
3D9BCB nothing more
3E1CC2 nothing more
3E5FA0  DKBKI http://www.rcawsey.co.uk/Arcus.htm and http://www.onlinecontest.org/olc-2.0/gliding/flightinfo.html;jsessionid=121227EC65EAD3AB8AE6397FA2DA6FAC?dsId=4436065
3FECE7  DMEPT no luck with the details
3FF428  DMGBJ no further information
406D22 decodes G-CIKY not sure about the details I found
451D9D nothing more
48416A nothing more
49C150  PHKBC hex range and flight id suggesting reg PH-KBC do not match up
4AC950 decodes SE-RJP http://www.airfleets.net/ficheapp/plane-md80-49209.htm somehow I doubt that it is that one
4CA1D5 nothing more
51000E nothing more
8000CF (two times) decodes VT-JCC which is now PR-PDK
89505E nothing  more
9803CF no country allocation
A200CF decodes N228XJ not assigned or reserved by FAA
EB03CF no country allocation
MILs:
* 3EAD1D  EIFEL                                                          2015/09/09 08:02:39
   3F4605  GAF534                                                         2015/09/09 06:12:23
   3F4605  GAF534                                                         2015/09/09 11:11:25
   3F627D  GAF824                                                         2015/09/09 08:39:51
   3F627D  GAF824                                                         2015/09/09 12:31:29
About the C-GTZQ issue from today morning:
My apologies, I never intended to offend you or to be impolite. I wrote the message at 0:40am after a very rude sleep interrupt. Obviously it isn't a brilliant idea to post a curtly and supposed to be ironic messages while you are still beeing in "sleepy anger". Lesson learned! Won't happen again (I hope).
Regards Ingo
Evening Ingo,
3E5FA0,D-KBKI,,Schempp-Hirth Arcus M
406D22 decodes G-CIKY but is now EI-***
49C150 is Czech and nothing with the hex on the Czech online register.  Tried PH-KBC on the Dutch online register and no hits
51000E,EW78827,1003499997,Ilyushin IL-76TD,Trans Avia Export
Nothing on the others and mil tac added.
Forget about this morning Ingo, the least said the better.
I almost forgot: some Routes from today early morning:
AFR381 F-GSQF ZBAA LFPG
SXD2833 D-ASXK EDDV GCFV (SXD2832 the way back)
TCX4963 G-TCDG LTBS EGBB
CYYZGUY
Mode-S C04788
Flight ID CGBCH
Only Mode-S / Flight ID populating
regards,
Jason
40" LED Monitor
40" LED Monitor
#2502
falcon,
One from yesterday, thanks to Chris on mode-s
3C5EC1,D-AGVA,5408,Gulfstream Aerospace GV-SP (G550) ex OH-GVA
Jason,
C04788,C-GBCH,D-9583,Beech V35B Bonanza,Aeromedico Inc
X
Still no sign of the FDB Jeddah flights recommencing but here are some new ones
FDB555  OMDB-VRMM     A6-FEH     B738  flydubai             2015/09/10 17:00:08
FDB556  VCBI-OMDB
FDB4242                        A6-FEO     B738  flydubai             2015/09/09
X
