0 Members and 22 Guests are viewing this topic.
CarlosAbreu
04-11-2022 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
CarlosAbreu
05-11-2022 Updated file in attach.
Carlos
q3qeq
#25160
Greetings, here are a few flights with wrong routes. Some flight numbers are on the map multiple times. Is there no automated process to fetch the latest flight plans and feed them into the system? Doing it manually seems tedious.
LH1016 / DLH7EK BLL -> N/A
LH2435 / BLH7EK BLL -> MUC
LH1925 / DLH8CF SVG -> N/A
LH879 / DLH8CF SVG -> FRA
LH1499 / DLH94N MUC -> N/A
LH1838 / DLH94N MUC -> TFS
LH1016 / DLH4CM HAJ -> MUC
LH2097 / DLH4CM HAJ -> MUC
EZY83BZ   / -      MAN -> N/A
U21885 / EZY83BZ MAN -> HRG
LH910 / DLH8LL MUC -> HAM
LH2066 / DLH8LL MUC -> HAM
Believe me updating manually is tedious, thanks
q3qeq
#25162
LH 1402 / DLH7AC FRA -> ARN
LH804 / DLH7AC FRA -> ARN
LH1380 / DLH7PJ MUC -> HAM
LH2072 / DLH7PJ MUC -> HAM
LH841 / DLH5CW FRA -> AMS
LH996 / DLH5CW FRA -> AMS
LH1375 / DLH9VT FMO -> MUC
LH2139 / DLH9VT FMO -> MUC
LH277 / DLH8CE FRA -> BLL
LH840 / DLH8CE FRA -> BLL
LH183 / DLH2WU FRA -> LCY
LH934 / DLH2WU FRA -> LCY
LH1096 / DLH67X FRA -> CDG
LH1040 / DLH67X FRA -> CDG
LH1604 / DLH4HX FRA -> CGN
LH946 / DLH4HX FRA -> CGN
LH974 / DLH7WK FRA -> GLA
LH24 / DLH7WK FRA -> HAM
DLH2YV / - BER -> MUC
LH1943 / DLH2YV BER -> MUC
LH1393 / DLH01P OPO -> FRA
LH1177 / DLH01P OPO -> FRA
LH2252 / DLH07E FRA -> LEJ
LH1106 / DLH07E FRA -> SZG
LH2304 / DLH6NH FRA -> AMS
LH1350 / DLH6NH FRA -> WAW
DLH1YE / - FRA -> PRG
LH1400 / DLH1YE FRA -> PRG
LH1004 / DLH3YY FRA -> KRK
LH1368 / DLH3YY FRA -> KRK
DLH5NY / - MUC -> HAM
LH2076 / DLH5NY MUC -> HAM
LH2093 / DLH2XY FRA -> HAM
LH28 / DLH2XY FRA -> HAM
DLH1AE / - OSL -> MUC
LH2455 / DLH1AE OSL -> MUC
LH2047 / DLH5UX FRA -> HAM
LH30 / DLH5UX FRA -> HAM
LH1411 / DLH5EL HAM -> FRA
LH31 / DLH5EL HAM -> FRA
LH2090 / DLH1RM ARN -> MUC
LH2414 / DLH1RM ARN -> MUC
Many thanks q3qeq.  Save yourself some typing and only give the current data, I will delete the old data when adding in the new stuff
Michel
Alan,
AFR83ZD LFPG-ESSA
BAW88P EGLL-EPWA
BLX4NV GCLP-ESGG
CSG2572 EHAM-ZGGG
DLH8EL EIDW-EDDM
EJU17ME EHAM-EDDB
EJU51UH EHAM-EGBB
EJU74PF EHAM-LIMC
EXS46Y EGCC-LGAV
EXS6RC LCPH-EGNT
EXS7RH LCPH-EGNM
EXS91N LCPH-EGCC
EXS96PX EGCC-LKPR
EZY48AJ EGCC-LKPR
EZY67MJ EGGD-EPKK
EZY86JR EGGW-EDDB
EZY94PK EKCH-EGKK
NVR704 GCTS-EKCH
PGT1JY EGCC-LTFJ
QTR77C EHAM-OTHH
ROT364J EHAM-LROP
SAS1549 EKCH-EHAM
SAS48D EHAM-EKCH
SAS527 ESSA-EGLL
THY1DP EGCC-LTFM
THY2TX LTFM-EHAM
TRA5336 HESH-EHAM
Michel
CarlosAbreu
06-11-2022 Updated file in attach.
Carlos
q3qeq
LH16137 / DLH3AH POZ -> MUC
LH1356 / DLH8YT FRA -> KTW
LH418 / DLH9W FRA -> IAD
LH1631 / DLH9CK WRO -> MUC
LH2287 / DLH5CR BRU -> MUC
LH2501 / DLH4HR MAN -> MUC
LH2193 / DLH3MM BRE -> MUC
LH1414 / DLH4NF FRA -> ZAG
LH1155 / DLH55E PMI -> FRA
LH2385 / DLH3LJ GVA -> MUC
LH1832 / DLH77W MUC -> AGP
LH2369 / DLH7XH ZRH -> MUC
LH1190 / DLH1PN FRA -> ZRH
LH2063 / DLH9E HAM -> MUC
LH2415 / DLH2KV ARN -> MUC
LH1613 / DLH2WT WAW -> MUC
LH1376 / DLH6EF FRA -> GDN
LH2441 / DLH3RK CPH -> MUC
LH8282 / DLH6UK FRA -> CPH
LH875 / DLH6MK BGO -> FRA
LH849 / DLH8PK HEL -> FRA
LH1643 / DLH7CJ GDN -> MUC
LH906 / DLH3MK FRA -> LHR
