0 Members and 122 Guests are viewing this topic.
#26236
Thanks Terry
Regarding your second post apart from one miscode the majority (Canadian/French/German/British/Swiss) are valid hex/reg tie ups from the country sequence and have no other details attached to them in the database as they have not been reallocated since de-registration.  As such they will be staying as is as hex/reg tie ups until they are reallocated
CarlosAbreu
04-12-2023 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
CarlosAbreu
05-12-2023 Updated file in attach.
Carlos
#26241
Terry
N281X is an RV8 and is in the d/b as such maybe a typo?
Not all de-regs will be left with the hex/reg tie up applied only certain ones (normally biz jets) per an Airnav customer requirement
CarlosAbreu
06-12-2023 Updated file in attach.
Carlos
ffa1978
600082 EW-557TG Antonov An-26b Genex
sples
https://www.radarbox.com/data/mode-s/855188
855188 is the decimal format of the hexcode 0D0C94, and 0D0C94 fits the Mexico range, so pls correct it.
Hi Spies
Unfortunately the hex code comes from the transponder of the aircraft and in this case the transponder is wrongly coded.  Nothing we can do about it, it will require the airline to have the transponder recoded correctly
855188 (decimal) decodes to 0D0C94 octal and it is in the database as such awaiting them correcting the transponder, however it was delivered out of TLS on delivery as VIV001 using 885188 on 1st August 2020 so i wouldnt hold your breath
