0 Members and 42 Guests are viewing this topic.
jdsd
Morning Alan
Please can you check VH-NJC   Mode 7C4316 Bae146 in my system but it is a Phenom300
The reason is I my laptop crashed  and have managed to get the system on a spare
I did a update this morning which shows 508479  but against aircraft it shows 234575
any clues how to resolve this matter
Many Thanks
John
Hi John
VH-NJC is in the d/b as the Phenom and I checked todays download and my NavData is showing it as such also.  I am showing 508090 rows in the aircraft table????
The phenom has been in the database since 2018 so I suggest that you are looking at the NavData that comes with the software download soam going to suggest that you have more than one instance of the software on your computer and the update is going to the wrong one
The best way to resolve this is to delete all instances of the Airnav software off the computer and once you have done the automatic de-installation you go in and manually delete all Airnav folders you find left behind, in addition to your root C;\ folders also check in program files in case there is anything in there.
When you are happy there is nothing Airnav left, Install to C:\Airnav do not install into programe files
If you want to keep any folders like logo, silhouttes that you have updated previously do so before anything else, save them to somewhere on your computer and use the to replace the dowanload folders
Once running again, do a d/b update and hopefully all will be well
jdsd
Hi Alan
Thanks for the info. I have tried everything but no luck, could the problem be that
I have a very old Airnav box ??
John
If you are seeing aircraft that shouldnt be the issue as everthing is in the software not the box and the software is on your computer
When you look at VH-NJC in the Aircraft tab of your Navdata what do you see?
jdsd
When I looked it was showing a 146   also  a Air Canada 330 was showing  B738  and one more  LX-JVC  was not showing PC24
John
#27155
John
LX-JVC in todays update as PC24 and has been since 2021 and none of the Air Canada A333's have an incorrect ICAO type code
It is therefore looking more and more like I described earlier
I have also noted no new entries I have made on the server database have made it into the Navdata and have advised Airnav with a request to fix ASAP
CarlosAbreu
16-08-2024 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
mikek
Another, hopefully I've not copied the wrong thing this time!
C82A55, ZK-MKV, Denney Kitfox III, 798 AACA/2013, Mr A C Dix
Cheers,
Mike
jdsd
Morning  Alan
Sorry to bother you, Which is the best version to use for my old radar box on a new laptop
John
Mike
Not have much luck
C82A55 ZK-MKV Sling Aircraft Sling 4 TSi c/n 275sk A C Dix
jdsd
CarlosAbreu
18-08-2024 Updated file in attach.
Carlos
