0 Members and 56 Guests are viewing this topic.
falcon_nl
Mode-S Messages:   11
So only 11 messages in 14 minutes
Yes look like a corrupt packet to me.
X
Ground test equipment at DXB
* 896ED2  AIR16                                                          2015/09/28 00:21:23
* 896EF8  TEST1234                                                       2015/09/28 00:12:43
* 896EF9  TEST1234                                                       2015/09/28 00:12:43
X
X
New unknown somewhere around the Istanbul area
* 504E2F        2015/09/29 21:20:13
X
CYYZGUY
#2765
40" LED Monitor
40" LED Monitor
X
This should decode to EP-ZAT A320 Zagros
* 736834  IZG4159  OIIE-LTBA                                             2015/09/30 03:05:27
* 736834  IZG4160  LTBA-OIIE                                             2015/09/30 04:46:06
X
X
#2767
Unknown f/n's around Istanbul yesterday
   KKK6203 ORER-LTBA                 TC-ATK     A320  AtlasGlobal          2015/09/29 21:41:10
   KKK8152                  TC-ETV     A321  Atlasjet/Royal Ai... 2015/09/29 22:02:11
   KKK8YL                   TC-ATF     A321  AtlasGlobal          2015/09/29 23:28:25
   PGT29V                   TC-CPG     B738  Pegasus Airlines     2015/09/29 22:33:43
   PGT56T                   TC-CPV     B738  Pegasus Airlines ... 2015/09/29 21:40:31
   PGT91C                   TC-AAT     B738  Pegasus Airlines     2015/09/29 20:40:31
   RFJ1511                  JY-RFF     B734  Royal Falcon Airl... 2015/09/29 21:05:43
   THY271/THY9PD LTBA-LUKK     TC-JVC     B738  Turkish Airlines     2015/09/29 20:45:48
   THY3796                  TC-JRG     A321  Turkish Airlines     2015/09/29 23:04:08
   THY3UF                   TC-JGZ     B738  Turkish Airlines     2015/09/29 22:05:29
   THY4ZS                   TC-JPB     A320  Turkish Airlines     2015/09/29 23:07:45
   THY4ZS                   TC-JPR     A320  Turkish Airlines     2015/09/29 23:01:03
   THY5167   OMED-LTBA  TC-JNS     A333  Turkish Airlines     2015/09/29 21:56:58
   TWI891                   TC-TLC     B734  Tailwind Airlines... 2015/09/29 21:26:28
NB Two THY4ZS flights within minutes with two different a/c so a bit confused with that one, probably pilot entry error
PS Huge thunderstorms on Monday so box was off
X
paul tricker
A few non populators
* 402DEB  GBPRX                                                          2015/09/29 16:43:17
G-BPRX  Aeronica 11AC  11AC-94  Alexander Florian Kutz
* A22DEB  00000000                                                       2015/09/29 20:39:00
decodes to N24CU, but not current on FAA
* 43C6EF  ABCDEFGH                                                       2015/09/28 13:45:21
As far as I can tell this is WK008, a Watchkeeper Mk1
* 39A56C  FHJLM                                                          2015/09/25 17:40:21
Other than a recent delivery I cannot find any details on this
Paul
X
Nothing on 504E2F.
736834 is EP-ZAT Airbus A320-214 c/n 999 Zagros Airlines
EP-ZAP will be 736830
I will keep an eye on the routes, I got a good number of your last batch done.
Paul,
402DEB,G-BPRX,11AC-94,Aeronca 11AC Chief,Alexander Florian Kutz
39A56C,F-HJLM,50500304,Embraer EMB 505 Phenom 300,Brit Aero
Regarding 43C6EF, noted the following from mode-s.  The Watchkeeper Hex codes should be treated as tactical, limited number of boxes shared between airframes in the UK.  I will put it in the d/b as in use by various Watchkeeper frames
Nothing on A22DEB
Morning Alan,
LLP8370 : LEMG-EPKT
VLG4580 : LEBL-GMMX
(Note the return to Barcelona according to the Marrakech departures board is VLG7333).
X
I made a mistake on this one it should be OEMA-LTBA!!
X
