0 Members and 168 Guests are viewing this topic.
diddyboy
Hi Alan
Understood, but definitely 5Y-LEO is using it as well.
Amendment C01EA3,  5Y-SLD DHC-8, c/n 331 still Showing in database as C-FLPQ.
Neil
Thanks Ian, one less for me to look for
#3092
Understand that Neil.  Can do two things, leave it correct as it is liable to be picked up in Florida or mark it as registration VARIOUS, ZZZZ as type etc with the comment in use by more than one aircraft in the CO column.  As we don't normally get Nairobi I would suggest we leave it in the Navdata with the correct entry and you can update your Navdata with the miscode  and change to No for auto update and that way you will get the correct details for the one you are picking up while in Nairobi
Amended 5Y-SLD, thanks
Alan,
Problem looming. Norwegian Air Shuttle would appear to have changed their ICAO from 'NAX' to 'IBK' which is a Norwegian Air International ICAO code. The boards at the airports are showing the new ICAO codes but can't tell at this stage which flights are affected.
Saw an IBK land at Alicante from Munich earlier.  Lots of IBK flights in the air at this time which will keep me occupied along with the others for a few days.
M
DLH5AE   EFHK   EDDM
DLH4WR   EDDM   EFHK
DLH3AJ   EDDF   EFHK
THY60R   EFHK   LTBA
FIN3ZP   EFVA   EFHK
IBK5870   EFHK   LIRF
IBK6WC   EFHK   EGKK
IBK5416   LEMD   EFHK
jim_stockwell
Hi Alan
Not populating is 3434CB with a flight i/d of B
Jim
AoD
Company update:
49D07B, OK-HCZ, Heli Czech
49D309, OK-KOV, Kovo CZ
49D2F0, OK-ADT, T-Air
Registration:
49D119, OK-THY  changes to OK-HLS
New:
49D0DD, OK-HIC, Robinson R44, c/n 0840, Heli Czech
Route:
WZZ8040   EPKT - LFOB
TRA1406   LTAI - EHAM
X
VT-CLF is a purple and white F2TH no winglets and no c/n found as yet
X
jim_stockwell
Hi Alan
Looking at my log 3434CB has been around since September! I think it might be PA-28 EC-LCY (Thanks to airframes) which has been at Elstree for a couple of months but has been re-registered as G-OFDR. So it is still using its old box
Jim
Michel
Alan,
TRA33B EHAM-LEBL iso EHEH-LEBL
Michel.
CYYZGUY
Hi Alan, a Sunwing missing some info which I find odd..
C078FD
SWG439
No Registration, Aircraft or company fields populating.
regards,
Jason
40" LED Monitor
40" LED Monitor
