1 Member and 41 Guests are viewing this topic.
CYYZGUY
40" LED Monitor
40" LED Monitor
X
DD927B  D-7301  Grob Astir CS  at Dubai Air Games
X
X
DD927B,D-7301,1184,Grob G 102 Astir CS,(Miscode)
Good Morning, unknowns from Thursday:
3D2DD3  DEPPJ http://www.luftfahrtclubbraunschweig.de/picdb/Uwe-Bethke-Privat-Vans-Aircraft-RV-4-RS-D-EPPJ-BWE-Braunschweig-Wolfsburg-13775.html
3D7504  DFQOI no further information
3FF448  DMZBV no further information
440838  OEKPY http://antonakis.co.uk/registers/austria/20150919.txt
471F6C nothing more
484B82 was PH-521 don't know if it's still valid
4BA9EF nothing more
740827 nothing more
EC0003 no country allocation
German MIL:
* 3E87F3  GAF401                                                         2015/12/03 09:35:18
* 3E87F3  GAF401                                                         2015/12/03 10:30:29
* 3E87F3        2015/12/03 11:50:30
* 3E9887  GAF213                                                         2015/12/03 09:29:22
* 3E9887  GAF213                                                         2015/12/03 19:21:56
   3E98F5  GAF263                                                         2015/12/03 09:20:23
* 3E9A76  GAF286                                                         2015/12/03 11:13:35
   3EA5D9        2015/12/03 14:01:58
* 3EAB3B  BOMBER                                                         2015/12/03 14:47:57
   3EBC96        2015/12/03 13:45:13
   3F4087        2015/12/03 09:10:06
   3F4087  MONSTR                                                         2015/12/03 10:13:46
   3F5361        2015/12/03 12:56:18
* 3F55E2  GAF301                                                         2015/12/03 08:18:17
* 3F5897  BARON2                                                         2015/12/03 11:20:59
   3F61CE  GAF163                                                         2015/12/03 16:11:19
   3F6537        2015/12/03 12:46:27
* 3F7CC2  DRAGON                                                         2015/12/03 09:31:12
* 3F7CC2  DRAGON                                                         2015/12/03 10:41:11
* 3F9370  KNIGHT1                                                        2015/12/03 09:21:48
* 3F9370  GHOST2                                                         2015/12/03 14:25:04
   3FA220  GOHST1                                                         2015/12/03 14:16:17
   3FB380  FATE1                                                          2015/12/03 07:04:30
   3FB380  BARON1                                                         2015/12/03 11:20:48
Regards Ingo
X
#3545
Two more not allocated codes
* 913900        2015/12/04 04:06:33
* CC4F23   BCC8831                                                 2015/12/04 13:31:32
The second is a B767 (seen) doing 400knots at 28000ft c/s is Business Air and plotting ex BKK!
X
Morning Ingo,
3D2DD3,D-EPPJ,,Van's RV-4,
440838,OE-KPY,1254,Cirrus SR22,ÖMA GmbH
484B82 which was PH-521 was cancelled and is now in Argentina and no new allocation on the Dutch register
Nothing on the others and mil tac added (hopefully all)
X
I have nothing on your miscodes
Hi Alan, this GAF hasn't populated:
Thanks Ingo, I knew I would miss one
Morning Alan,
My mistake VLG8248 is LFPO-LEAL not LFPG-LEAL. The return is VLG8249.
EVE1111 : LEAL-LEBB
EVE1112 : LEBB-LEAL
X
#3551
According to the db Business Air only have one current B767 so is possibly my miscode CC4F23 being ex BKK, unless it is a stored one on the move as it seems to be headed to Europe
X
X
Two more Gliders up at the Dubai Air Games and they plot!
DD50CA  WAG-GL1
DD50CC  WAG-GL2
X
X
Business air went bust in January but were rebranded Intira Air in June under new ownership and from what I can see they operate one B763 HS-BID 880924 with 5 aircraft returned to their lessor.
