0 Members and 27 Guests are viewing this topic.
falcon_nl
Ok thanks Alan,
But this morning when i looked it was EI-CCF an AR11 ;)
Yes but where did you look?  On Planeplotter it was EI-CCF and on FR24 it was EI-FHF but it was eyeballed at Gatwick as EI-FHO.
phelpsl
Just did a database update.  4CA5BB = EI-FHO but showing as type AR11 instead of B738.
Cheers,
Les
CYYZGUY
40" LED Monitor
40" LED Monitor
diddyboy
Hi Alan
one unknown South African from Djibouti yesterday
* 0082D3        2015/12/05 07:04:02
Neil
jacobite
Hi Alan, could you tell me please, has radarbox been updated from 5.00.072
Undertaker
Just up from Farnborough [EGLF] around 0815L was Be300 N352JP [FL-274] hex code A3ED11 call sign showing as SSZ241A, Specsavers new aircraft ?
Tony
Les,
Just checked 4CA5BB and it is ok in both the server and on the d/b update from this morning.  I can only presume the update you did was from yesterday or the details you have were already in your d/b.  What is the ch date you your one.
The one I downloaded this morning shows that I entered it into the d/b yesterday at 1215 as per the attached.  I am sure that if you download todays update it will be correct.
Hi Neil,
0082D3 decodes to ZS-BBE and I can find no details on any current or previous users of the registration.
Ian,
I believe there is a beta of V6 for use with usb dongles out for bet a testing.  I believe it is the same as V5 except you can use with a dongle
#3595
Tony,
Caught it over the Irish Sea heading to Belfast
A3ED11,N352JP,FL-274,Beech B300 King Air 350,American Aviation
It is ex- M-SPEX cancelled the other day so maybe heading to the US.
X
#3597
* 344605  CASA942                                                      2015/12/06 14:13:20
   84BBB8  JA227J                                                         2015/12/06 09:09:51
   A201C0  2285                                                           2015/12/06 09:31:28
I think the latter miscode is UAEAF  AT8T 2285 as it is up nearly everyday, so they probably have recoded its previously miscoding box to hex of N2285 (similar exercise to that done to the new Bells)
X
X
344605,142,S.142,CASA C295M,Philippine - Air Force (Miscode) on delivery
84BBB8,JA227J,17000524,Embraer 170-100STD,J-Air/Japan Airlines
A201C0,2285,802-4007,Air Tractor AT-802U,United Arab Emirates - Air Force (Miscode hex of N2285)
X
* AAE67D        2015/12/06 14:56:47
FAA states AAE67D is N801KH Thrush S2R-T660  T660P-101DC  Status Valid
X
