0 Members and 32 Guests are viewing this topic.
falcon_nl
Ok thank Alan for D-ADSK, next unknown
447D41, Callsign ABCDEFGH
falcon
Likely to be C-130K 8X-CZ out of St Athans on its way to Linz for the Austrian Air Force where it is to be used for spares so possibly the last we shall see of it.  Ex RAF XV295
Hawkeye
Not popping:-
4CA58D EI-FMJ AT76 ATR-72-600 1295. Stobart Air .
Syd
#3634
It should Syd as it has been in the d/b since delivery 27/11 and checked the d/b and it is in correctly.
Got it on my screen at this time.
falcon_nl
Again a unkown:   E49234, Callsign: TAM9950
falcon,
Out of XFW on delivery E49234,PT-XPL,6895,Airbus A321-211,TAM Linhas AƩreas
AoD
SOP5132   EDDP - LHBP
THY6502   DGAA - EHBK - LTBA
MNB9345   LTBA - EDDP
CYYZGUY
40" LED Monitor
40" LED Monitor
diddyboy
Hi Alan
Currently back at Nairobi Wilson and a few updates for you.
034056  TJ-PAX Do228 c/n?
04C172  5Y-SMZ F50 c/n 20192 Skyward International Aviation
A07E92  5Y-MAE C208B c/n 208B1155 (Old Hex code of N1307V)
04C102  5Y-CCS Do228 c/n 8152 Bluewave Aviation.
Neil
Hi Neil,
034056,TJ-PAX,,Dornier 228-202 can find nothing on it.
04C172,5Y-SMZ,20192,Fokker 50,Skyward International Aviation
A07E92,5Y-MAF,208B1155,Cessna 208B Grand Caravan,(Miscode hex of N1307V)
04C102,5Y-CCS,8152,Dornier 228-202K,Bluewave Aviation
Many thanks
diddyboy
Hi Alan
4 more for you
48415B,  5Y-VVG Fokker 50, c/n 20137 Bluebird Aviation (Using old Hex of PH-DMK)
A6BD10,  5Y-DMF Cessna 182, c/n 182-62419 Private (Using old Hex of N533RG)
A1F01F,  5Y-CDF, Beech 350, c/n FL-60 Private (Using old Hex of N224CR)
A02E3E,  5H-RES, Cessna 208B, c/n 208B 1020, Regional Air Service (Using old Hex of N110WY)
Neil
