0 Members and 17 Guests are viewing this topic.
diddyboy
Hi Alan
a few more from Wilson
00B0E6, 5Y-FAB, EMB-120, c/n 120162, Freedom Airlines Express
04C07D, 5Y-VVA, LET-410 UVP-E9, c/n 962633, Blue Bird Aviation
04C13D, 5Y-FAE, EMB-120, c/n 120156, Freedom Airlines Express
080041, 5H-ETG, Cessna 560, c/n 560-0070, Corporate.
04C0BC, 5Y-BTX, Bell 407, c/n 53929, Corporate
According to various websites and Mode S links Hex 080041 was used by 5H-PWH ATR42 of Precision Air, but defo being used by the Citation as see below reg used in callsign on the box on arrival at Wilson and on departure as well.
Neil
080041  5HETG                    5H-PWH     AT46  Precision Air Ser... 2016/01/09 15:07:29
080041  5HETG                    5H-PWH     AT46  Precision Air Ser... 2016/01/09 16:25:58
falcon_nl
Unknown:
39BC81, callsign FHPEB
Many thanks again Neil.  Looks like we may have two using the same hex unless the AT46 has changed as I believe it used 080041 on delivery.  Both aircraft went on the register around the same time in 2012.
From yourself on 4th January
5H-PWH, ATR42-600, c/n 1001 PrecisionAir is down in database as 5N-PWH (can you Amend Please) - Did you pick up the aircraft or just note the error in the d/b.  If you noted it, what hex was it using?
falcon.
39BC81,F-HPEB,45-2080,Learjet 40XR,ADD ex D-CPDR
diddyboy
Hi Alan
Didn't actually see PWH on the 4th, just noted it in the DB as 5N.
Neil
Cheers Neil, thought that would be the case.
M
ADR7168   EDDM   EETN
APF98   ESSA   ESNU
FIN119   EFHK   EETU
FIN120   EETU   EFHK
FIN129   EFHK   EVRA
FIN565   EFHK   EFKI
FIN566   EFKI   EFHK
FIN567   EFHK   EFKI
FIN568   EFKI   EFHK
FIN4HB   EFIV   EFHK
FIN225   EFHK   EFTU
FIN746   EPWA   EFHK
FIN595   EFHK   EFKK
FIN596   EFKK   EFHK
484364 / P4-AGL / CL35 / Bombardier BD-100-1A10 Challenger 350 / AGL Sky / 20596
X
We believe these are two H60'S at Minhad
* AE4D3A        2016/01/10 12:57:09
* AE4D42        2016/01/10 13:18:51
X
Hi X, I don't have anything on them but believe you may be correct on your assumptions
paul tricker
This is up & about in SE England around the 3,000ft mark
A986FD  N7128T                                                         2016/01/10 10:30:56
Unfortunately the FAA site just shows it as a reservation
Paul
Paul,
As you state its not allocated so I am going to suggest that it is G-DSJT miscoding its previous ID and was registered by the CAA 21/12.  It came down over here landing at Prestwick for fuel on delivery using the US hex and registration.
paul tricker
Cheers Alan, that would make sense
Paul
falcon_nl
New one: 48508E, PH-JQA, 4017, DH8D, Bombardier DHC-8-402
Unknowns: 3E4515, DIRIZ
4AC99C
