0 Members and 27 Guests are viewing this topic.
Evening Alan, unknowns from Monday:
1218F1 nothing more
1C542B nothing more
3CA974 nothing more
3E37AE D-IMHA https://www.luftfahrtclubbraunschweig.de/picdb/Swen-E-Johannes-MHS-Aviation-Cessna-525A-CitationJet-2-D-IMHA-BWE-Braunschweig-Wolfsburg-13906.html
4891BF nothing more
502C79 was YL-LCG A320 no information about a new airframer using this reg/hex
57A6D7 no country allocation
A400CE decodes N357WM and is assigned by FAA: http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N357WM
MILs:
* 3E836B  GAF655T                                                        2016/02/01 09:23:43
* 3E8B1B  GAF781                                                         2016/02/01 11:01:43
* 3EACD3  GHOST01                                                        2016/02/01 09:27:15
* 3F6948  GAF767                                                         2016/02/01 13:36:00
* 3F9EEA  HG01A                                                          2016/02/01 13:22:05
Regards Ingo
Evening Ingo,
3E37AE,D-IMHA,525A-0322,Cessna 525A CitationJet CJ2+,MHS Aviation
A400CE,N357WM,BG-357,Beech T-34B Mentor,Gripnet Inc another unlikely one for over here but added in anyway
Nothing on the others and mil tac added
Michel
Alan,
CND112 GBYD-EHAM iso LGMT-EHAM
Michel
falcon_nl
Unknown :  3CA91A Callsign DCPOS
I don't have any info but whatever it is falcon it is miscoding.  3CA91A decodes to D-BJHZ and C-CPOS should be 3CE91A
#4372
I had 3CE91A DCPOS in my range here in Heidelberg. While in my range it descended from 31000ft down to 26200ft. Reception time was 18:10 to 18:15 UTC. No ADS-B received. I wasn't able to find any information either. So, no miscoding but bad packets received if falcon had 3CA91A with flight id DCPOS.
Thanks for the info Ingo, I am sure it will all come to light in the coming days.
CYYZGUY
A512BE
Nothing else populating
regards,
Jason
40" LED Monitor
40" LED Monitor
falcon_nl
#4375
Made a typo yesterday for D-CPOS it was 3CE91A, and the plane is now again airborne and looks like they are landing at Essen/Mülheim (EDLE)
And a unknown 44D982 with no callsign
Jason,
A512BE decodes to N426JN not allocated by FAA
falcon,
Still nothing on D-CPOS AND 44D982 decodes to OO-VLB not allocated possible corrupt packet?
falcon_nl
Ok another unknown: 3C2BC2 callsign MHV300 (MHS Aviation)
Afternoon Alan,
In d/b but needs recycling :
AZA878 : LIRF-GMMX. The return is AZ879.
