0 Members and 23 Guests are viewing this topic.
#4455
Ian,
What is your source regarding D-ALER.  N273DH is still showing as current on FAA http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=273dh
N273DH is due to become D-ALER following its freighter conversion but I can find no details that it has been delivered yet.
The issue with the aircraft table in the Navdata update has been fixed and the table downloads correctly
Alan,
Source for D-ALER is the 'planespotters´website and you are correct (again) it just states 'due' !
GAS website for the ATR 72.
Cheers Ian.  GAS probably got it via here or my post on mode-s
falcon_nl
Unknown: 4B95BA Callsign TCEMZ
Thanks falcon
4B95BA,TC-EMZ,1613,Cirrus SR20
falcon_nl
Second unknown: 45BF2F callsign OYOYO :)
Here you go falcon
45BF2F,OY-OYO,RK-354,Beechjet 400A,IQ Charter
Good evening Alan, unknowns from Tuesday:
070E88 nothing more
3C48BD nothing more
47177C  5ZVX   Y no further information
A6BD36 decodes N533SV and is currently not assigned/reserved by FAA
F88000 no country allocation
MILs:
* 3E92B9  GAF807                                                         2016/02/09 11:47:58
* 3E92BD  GAF807                                                         2016/02/09 09:11:36
* 3E92BD  GAF807                                                         2016/02/09 11:34:24
* 3EAA8B  GAF767                                                         2016/02/09 10:56:05
* 3EAA8B  GAF767                                                         2016/02/09 14:55:28
* 3EB584  GAF729   EGPF-EDDK                                             2016/02/09 10:34:03
* 3F53D9        2016/02/09 08:55:56
* 3F7D01        2016/02/09 09:19:43
* 3F979E  GAF392                                                         2016/02/09 13:57:46
* 3F9D72  GAF696                                                         2016/02/09 09:32:21
* 3F9E9C  TORO                                                           2016/02/09 07:09:15
* 3F9E9C  TORO                                                           2016/02/09 13:23:15
Regards Ingo
Thanks again Ingo,
Nothing on your unknowns but mil tac added and did you note the post advising the update is now working OK
paul tricker
Previously noted still using the code from its former American reg, it looks as though somebody has had a (bad) attempt at re-coding this E35L
* 5190B0  XAKAD                                                          2016/02/10 17:14:45
Paul
X
* 4D20C1  9HAGI                                                          2016/02/10 20:36:02
X
paul tricker
X
Niger and Ukraine unknown
* 0620AF        2016/02/11 05:49:44
* 508367        2016/02/11 01:20:40
X
Thanks Paul, noted it in logs this morning and added in the miscode
