0 Members and 34 Guests are viewing this topic.
falcon_nl
#4727
Unknowns:
3DAEEC callsign DGMMM
3D4195 no callsign
falcon,
5000B4,T7-ISH,60-369,Learjet 60,Anda Air as advised by Sean Meagher
3DAEEC decodes to D-GMMM as you show but no info yet
3D4195 decodes to D-EXBX no info yet
Afternoon Alan, unknowns from Thursday (after cleaning)
3C5EA3 nothing more
3CE66B nothing more
3CF307  AYY111 AYY: Air Alliance Express
3D190D  DEHSV no further information
47AB16 http://www.flightradar24.com/data/airplanes/ln-fts/
490D05 nothing more
4CA297 was EI-MEJ I haven't foiund any information about a new airframe with this reg/hex
4CA60D  IBK5503 IBK: Norwegian Air International
50830D nothing more
89906E  EVA321   EDHI-VTBS I read the posts/diskussion about this one. So, I'll get this one with the tomorrow db update.
MILs:
* 3EA0EA        2016/02/25 12:49:43
* 3EB921  RAVEN1                                                         2016/02/25 07:51:42
* 3EB921        2016/02/25 08:54:59
* 3F81B9  JUSTIS                                                         2016/02/25 13:23:37
I tested manual populate and 3 hour before the 48h will end it's still not working...
Regards Ingo
#4731
I wouldn't hold my breath that it will be done Ingo
3CF307  AYY111 decodes to D-CTIL and question was asked on mode-s yesterday and no replies
47AB16,LN-FTS,,Diamond DA 40 NG Star,Pilot Flight Academy no c/n details known
4CA60D  IBK5503 not known to me yet which one has been re-registered
Nothing on the others and mil tac done
falcon_nl
3D1BB7 should decode D-EITB, but I havn't found any information about an airframe with this reg.
falcon,
3D1BB7 decodes to D-EITB which I have no information on.  The previous user of the Registration was A C150 which went to Russia
Evening Alan, unknowns from today. Hopefully they make it to tomorrows db release. Got other business to do by a request from Andre.
43EB45 http://www.flightradar24.com/data/airplanes/2-paoh/
48978D nothing more
49C0F1 nothing more
506C08 decodes S5-AAH last info I found that this one is stored since 2011
A34C5C decodes N311UT not assigned or reserved by FAA, so bad packet received I guess
F3ADF2 no country allocation
MILs:
* 3E9937  GAF061                                                         2016/02/26 13:12:15
* 3E9937  GAF061                                                         2016/02/26 14:51:49
* 3EADF2  RAGE                                                           2016/02/26 09:40:25
* 3F67A2  GAF696                                                         2016/02/26 08:41:05
* 3F7701  SEAL                                                           2016/02/26 08:26:24
Hi Ingo,
43EB45,2-PAOH,811,Airbus A330-203,AerCap Aviation Solutions up on a test flight out of EHAM, to become AP-BMI with Shaheen
Nothing on the others and mil tac added
49C0F1 nothing on the Czech register
S5-AAH became C-GMGY and was stored for part out in Canada 2011
Thanks again and no reason why they shouldn't be in tomorrows update as they are in the database. Have a good weekend
Hi Alan, as you have processed them they are in the db now. But, maybe, for some unimaginable reason you could have something "better" to do as to investigate unknown airframes to add them to the db. Have a good weekend too. I'll spend mine with intense torturing, well I mean testing of RB24.com
Michel
Alan,
PRI454 LEMG-EKBI
PGT476 EHAM-LTFJ
Michel
You have fun testing Ingo, I will stick to the easy stuff
