0 Members and 108 Guests are viewing this topic.
I don't have anything on the code X
Blueboy
Hi Alan, you have probably changed it already but picked up HEX 4CA676 which showed as PA-31 EI-DIF in database but appears to be new B738 EI-FOS
J.D
I changed it yesterday so should be OK with todays Navdata download.  Looks to be a re-allocation of the hex
falcon_nl
Unknown: 3D5535 callsign DFEND
Nothing on it yet falcon
Northern Watch
Hi Alan
I noticed that mil tac code 3F7DCD did not populate but the other did from those I sent you yesterday?  Also picked up the following a few days ago but I have my doubts about it as I only had 3 message counts and I think it is a ULAC From the Manchester area although the height would be about right,  showing at 01440 feet. The code was 406DA9.
Best Regards
Keith
Hello Alan, unknowns from Monday:
3E345F nothing more
9875C1 no country allocation
AC6D19 decodes N90CV currently not assigned or reserved by FAA
MILs:
* 3E959B  SABRE52                                                        2016/03/07 14:18:03
* 3EBF10  GUNNER1                                                        2016/03/07 19:25:07
* 3F4886        2016/03/07 09:35:50
* 3F4886  GAF197                                                         2016/03/07 12:07:08
* 3F4886  GAF197                                                         2016/03/07 14:57:29
* 3F4886  GAF197                                                         2016/03/07 16:23:00
* 3F9EE3  GAF019                                                         2016/03/07 09:02:15
* 3FAE5D  GUNNER2                                                        2016/03/07 19:47:09
* 3FB0C1  EIFEL                                                          2016/03/07 19:16:44
Regards Ingo
Sunday:
15211B nothing more
343691 nothing more
345055 nothing more
394C16 nothing more
44046A no active airframe found
4CA374 EI-FGT stored, ex 9V-SQI is the latest info I found
4CA60A no active airframe found
503D11 nothing more
5082ED nothing  more
71BF5E nothing more
8800F4 nothing more
Saturday:
3CC2BB nothing more
3D190D  DEHSV still no luck with the details
4AC969 nothing more
896461  ETD9001 A6-APF A388 so already in db I guess
896465 possibly a bad packet of the airframe above...
Friday:
39968B  AAF046T F-HFUL A320 already in db I guess
3CF307  AYY111 again and still no luck with the details
3D190D  DEHSV already posted today...
475EEB nothing more
4AC8BD nothing more
4CC4E2 TF-KFH http://www.icetra.is/aviation/aircraft/register?aq=TF-KFH
MILs:
* 3E9D55  GAF151                                                         2016/03/04 15:47:31
* 3E9D55  GAF151                                                         2016/03/04 17:27:54
* 3F4AC0  GAF298   LPLA-CYYT                                             2016/03/04 09:57:34
* 3F4AC0  GAF298   LPLA-CYYT                                             2016/03/04 11:43:20
* 3F6443  GAF798                                                         2016/03/04 08:56:29
Back-Log finished!
Hi Keith,
No idea what I did but I had not added it to the d/b, its in now.
406DA9,G-CIMH,8706,P&M Aviation Quik Lite,P and M Aviation
Evening Ingo,
Monday, nothing on your unknowns and mil tac added
Sunday, nothing on your unknowns
Saturday
896461,A6-APF,195,Airbus A380-841,Etihad Airways
Nothing on the others
Friday
39968B,F-HFUL,2180,Airbus A320-214,Aigle Azur,
4CC4E2,TF-KFH,40.N268,Diamond DA 40 NG Star,Keilir Aviation Academy
Nothing on the others and mil tac done
Many thanks
falcon_nl
#4872
Found a few new one's:
3C66B3, D-AIUS, 7024, A320, Airbus A320-214(WL), Lufthansa (DLH)
3DE009, D-HFCB, 0135, R44, Robinson R44 Astro, Reibel Air
And also a few unknown: 3C6620, 34449E no callsigns, 3CC2E3 callsign DCBCT
Thanks falcon,
3DE099 is unallocated, does not decode
3C6620 decodes to D-CBCL which is unallocated.  However D-CBCT is 3CC2EB,D-CBCT,525C-0093,Cessna 525C CitationJet CJ4
Evening Alan, unknowns from Tuesday:
056C94  RJZ361 http://www.flightradar24.com/data/airplanes/361/
08AB00 nothing more
3445CC nothing more
3C4873 decodes D-ABCS no airframe with this reg found
3CD558 decodes D-CICE, no active airframe with this reg found
3D32BE  DERLU still no luck with the details
3D5535  DFEND posted yesterday and srtill no luck with the details
5000B6 nothing more
MILs:
* 3E9A4B  NITRO1                                                         2016/03/08 14:22:39
* 3EB5A8  GAF640                                                         2016/03/08 08:19:47
* 3EB5A8  GAF640                                                         2016/03/08 12:25:31
* 3EBE2E  JUSTIS                                                         2016/03/08 14:25:37
   3F83EA  LK01A                                                          2016/03/08 18:36:51
* 3F86E2        2016/03/08 13:47:34
* 3FB72A        2016/03/08 14:12:46
Regards Ingo
