0 Members and 97 Guests are viewing this topic.
falcon_nl
#4950
Unknown:
4D0286 callsign LXYES
http://www.jetphotos.net/photo/7639393
New one:
4408A9, OE-GBC, Cessna 525B, 525B-0219, Airlink Luftverkehrsgesellschaft mbH (JAR)
X
Re AE0658 KC135T it is regular over here as 59-1462 last seen in August 2015 but was noted in 2013/14 as well
X
Hi falcon
4D0286,LX-YES,3528,Cirrus SR22
4408A9,OE-GBC,525B-0219,Cessna 525B CitationJet CJ3,Airlink Luftverkehrsgesellschaft
X
4CA12E  ISS2032  LIRF-OMAD       EI-FFK     B738  Meridiana            2016/03/16 07:28:26
This time it is is LIRF-Sharm el Sheikh - Minhad
X
Good Morning Alan, the unknowns from Monday:
3CC251 nothing more
3D190D  DEHSV received again, still no details
3D666F  DFLAT was already posted on day of reception by falcon_nl, so I guess it was added after it was in my range
3E05A9  DHTIN http://www.helionline.net/954-707257-931802/photogallery/15/250/45670///D-HTIN+2955.html
3E467F nothing more
43EA68 http://woodair.net/Manx_Register/ManxRegister_ModeS2.htm
   4CA619  IBK2TK   LEMG-EKCH                                             2016/03/14 08:35:31
   4CA619  IBK71W   EKCH-LEMG                                             2016/03/14 11:02:30
   4CA619  IBK5596  LEMG-EDDH                                             2016/03/14 17:39:08
   4CA619  IBK5597  EDDH-LEMG                                             2016/03/14 20:27:03
no further information (strange)
7583E2  PAL5006  RPLC-KSFO A321 on delivery, as usual added after it came in my range I guess
7BAACE nothing more
895052 nothing more
89646D nothing more
MILs:
* 3F4A58  SHOCK42                                                        2016/03/14 18:33:36
* 3F6E7F  SLAYER1                                                        2016/03/14 09:04:34
* 3F8FEE  GUNNER2                                                        2016/03/14 09:35:50
* 3F8FEE  NITRO3                                                         2016/03/14 14:25:34
Regards Ingo
Tuesday unknowns:
3CEFFD nothing more
3D666F  DFLAT auto-populate seems not working for this one, will try populate later...
4008C6 nothing more
44005A was OE-LKD D328 I haven't found any indication that there is a new airframe using this reg/hex
440556 nothing more
4AC991 nothing more
4CA1A8 nothing more
Again:
   4CA619  IBK2TK   LEMG-EKCH                                             2016/03/15 08:43:39
   4CA619  IBK71W   EKCH-LEMG                                             2016/03/15 10:56:19
   4CA619  IBK4PQ   LEMG-EKCH                                             2016/03/15 17:39:47
   4CA619  IBK3KF   EKCH-LEMG                                             2016/03/15 20:17:11
4D0286  LXYES already posted by falcon_nl, was in my range before it was added
MILs:
* 3E9F8C  GAF183                                                         2016/03/15 12:55:50
* 3E9F8C  GAF183                                                         2016/03/15 14:07:24
* 3F7478  GAF267                                                         2016/03/15 08:38:52
   3F8FEE  GHOST2                                                         2016/03/15 14:34:59
   3F8FEE  APEX                                                           2016/03/15 18:55:41
Thanks X,
Strange they are allowing a military fields to be used instead of one of the many civil fields in the area
#4958
Ingo,
Monday
3E05A9,D-HTIN,2905,Eurocopter EC225 LP
43EA68 was M-ABIR A320 which is now B-LCJ with Hong Kong Express Airlines and I am not aware that it has been re-allocated
4CA619,EI-FJR,36820/3131,Boeing 737-86N,Norwegian Air International,re-registered as per reply to falcon on Monday
7583E2,RP-C9925,7015,Airbus A321-231,Philippine Airlines added shortly after departure from XFW
Nothing on the others and mil tac added
Ingo,
Tuesday
D-FLAT is in the d/b correctly
LX-YES came out of EDDB if my memory is correct and routed to Luxembourg and was on approach when I saw it.
Nothing on the others not previously mentioned and mil tac done.
falcon_nl
New one:
440832, OE-FYD, DA42, Diamond DA-42 M-NG, 42.MN051, Diamond Aircraft Industries GmbH
Thanks falcon, caught it not long out of the factory and it looks like it is heading your way.
Morning Alan,
Non populator just on :
359284
Flight ID : TURIA 71
silverjet102
Good morning Rod,
Please find attached Summer 16 SXS and SXD planned call signs.
Cameron
silverjet102
Hi Rod,
The following need adding to the route table as missing when I saw them on Sunday
DJT006 routes LTN-EWR
DJT007 routes EWR-LTN
Cameron
