0 Members and 24 Guests are viewing this topic.
paul tricker
49D27F  OKNNN                                                          2016/08/16 14:41:25
OK-NNN  Zlin 526F
picture here shows 1271 on the tail, but no idea if that is the c/n
http://www.planes.cz/en/photo/1212592/z526f-ok-nnn-private-olomouc-lkol
Paul
Cheers Ian, known to us all now
Hi Paul,
As per the Czech register 1271 is its c/n
#6888
Morning Alan,
TVS2Y : GCRR-LKPR
AFR1530 : LFPG-DAOO not LFPO-LEMD
VLG6231 : GCFV-LIRF not EGKK-LIRQ
OBS5303 : LPPT-LEPA
OBS5306 : LEPA-LPPR  (This is the return flight for the above. Note it is returning to LPPR not LPPT).
The above Orbest flights are by CS-TRL A320 c/n 3758 which was operating on lease to Evelop. It would now appear to be back with Orbest.
Michel
Alan,
KLM407 EHAM-UACC-UAAA iso EHSM-UACC-UAAA
TFL218 LGMT-EHAM iso LGSM-EHAM
CND795 EHAM-LGMT iso EHAM-LGZA
CND217 EHAM-LBBG iso EHAM-LGIR
Michel
Good Afternoon/Evening Alan, unknowns Aug 16th
3DB145  DGNJP (2x) http://www.flugzeugforum.de/threads/80934-Flugbetrieb-am-Siegerland-Flughafen-EDGS/page5?p=2313286
3E388C  DIMPO (2x) still nothing new
3E7187  DKIEP (2x) http://www.airport-data.com/aircraft/photo/001200421L.html
MILs:
* 3E81F9  GAF959                                                         2016/08/16 07:58:35
* 3E8FFF  GAF044                                                         2016/08/16 09:32:06
* 3E9206  GAF113                                                         2016/08/16 07:20:56
* 3E9206  GAF113                                                         2016/08/16 09:00:15
* 3E96F8        2016/08/16 11:57:06
3FEF57  DMBZT http://www.jetphotos.net/photo/8233583 http://www.flugzeug-bild.de/bild/kleinflugzeuge~sportflugzeuge~breezer-b-600/66510/d-mbzt-breezer-b600-lsa-die-d-mbzt.html
3FF37D  DMSRC still no luck with the details
3FF3D5  DMJDI (2x) no further information
3FF510  DMHVN no further information
Regards Ingo
Evening Ingo,
3DB145,D-GNJP,,Diamond DA 62
3E7187,D-KIEP,44668,Scheibe SF 25 C Falke
3FEF57,D-MBZT,,Breezer Aircraft Breezer CR
Nothing on the others and mil tac added
falcon_nl
#6894
Evening Alan,
Here is the list from 2 days:
3D4400, D-EYAR, C172, Cessna 172 Skyhawk, Luftfahrtverein Essen
3E62F2, D-KCRA, G109, Grob G109B
485173, PH-YBM, E0005, PNR3, Alpi Aviat Pioneer 300 Hawk
484483, PH-3Z6, 0606-6827, C42, Comco Ikarus C42B
3DE5A3, D-HHFF, 5155, AS55, AƩrospatiale AS 355F2 Ecureuil 2 http://www.jetphotos.net/photo/8248926
3D13AA no callsign
3FF485 callsign  DMRRC
4AB542 callsign SEMJB
3FF476 callsign DMEMZ
3FEB8B callsign DMPEI
49C0F1 callsign OK-TUA76
Evening falcon.
The correct code for D-EYAR is 3D4419 and its a Cessna 172P Skyhawk c/n 17274351
D-KCRA is c/n 6520
3D13AA decodes to D-EFRU but can find no Other info
4AB542,SE-MJB,3633,Cirrus SR22
3FEB8B,D-MPEI,076,Tecnam P-96 Golf,
Many thanks
Cheers Terry many thanks
jim_stockwell
Hi Alan
Not populating was a netjets hex 4D2114 which GAS has a GBX XRSc/n 9429 reg 9H-LXX
Jim
Cheers Jim
4D2114,9H-LXX,9429,Bombardier BD-700-1A10 Global Express XRS,VistaJet Malta
Many thanks
M
FIN4RX   ENGM   EFHK
FIN717   EFHK   LKPR
SAS72Y   ESSA   ESNZ
SAS73B   ESNZ   ESSA
ADR7242   LDRI   EETN
SSF9590   ULWC   EFHK
CLU318   EFHK   UUEE
CLU317   UUEE   EFHK   via EDDF
CAO8404   EDDF   ZSPD   via ZBTJ
CLU517   UUEE   EDDF   via EFHK
71C071 / HL8071 / A321 / Airbus A321-231 / Asiana Airlines / 7266
Miscode in one transponder (allocated 4851F2):
485172 / PH-BCI / JS32 / British Aerospace Jetstream 3201 / AIS Airlines / 953
