0 Members and 56 Guests are viewing this topic.
Aug 26th:
0641C9 DAV490 still no luck with the details
39543C  FJAIP no further information
3D1400  DEFVC D-EFVC Piper Archer III  Frankfurter Verein für Luftfahrt von 1908 e.V.  along with D-ELZC found here: http://www.wherevent.com/detail/Frankfurter-Verein-fur-Begrussungsfest-und-Flugzeugtaufe
3D1C8D  DEJBH https://planefinder.net/data/aircraft/D-EJBH https://www.planespotters.net/photo/563007/d-ejbh-private-centre-est-aeronautique-dr.300108-22-tricycle
3E1E09  DICON no luck with the details either
3E38B3  EFD666 https://www.e-aviation.de/ru/unsere-flotte/beechcraft-king-air-c90/
MIL:
* 3E9212  GAF007                                                         2016/08/26 17:54:52
   3E964F        2016/08/26 07:42:20
* 3EA116  HG01A                                                          2016/08/26 06:25:00
   3EBDB0  DRAGON                                                         2016/08/26 09:07:24
* 3F5C51  SHARK2                                                         2016/08/26 08:16:29
* 3FAEFE        2016/08/26 07:08:09
To be continued later...
falcon_nl
Morning Alan,
List from yesterday:
3E5C0B, D-KABB, RF5, Fournier RF-5, FSV Wächtersberg
3FF0A6, D-MZEM, C42, Comco Ikarus C42
3FF2CD callsign DMQQM
3EC391 callsign DKPAF
3EF7B1 callsign D5914
3E73D0 callsign DKJBC
Aug 26th continued:
3FF171  DMPCT posted within Aug 25th
3FF23B  DMRHH same as above
3FF2D6  DMMSE still no luck with the details
3FF3D5  DMJDI (2x) no luck with the details
3FF427  DMVGT (2x) no luck with the details
3FF4D5  DMSWK http://www.flugzeugforum.de/threads/70529-Flugbetrieb-in-Borkenberge-EDLB/page76?p=2327803
3FF531  DMWBG no further information
49C0F1  OKTUA76 (2x) still no luck with the details
7100BF  SVA9031 https://www.planespotters.net/airframe/Boeing/777/61595/HZ-AK31-Saudi-Arabian-Airlines http://www.skyliner-aviation.de/regdb.main?LC=nav4&page=3
Regards Ingo
Morning Ingo
25th
3FF171  D-MPCT I believe this to be a Flight Design test registration as my d/b shows 4 FD aircraft previously using the registration but are now using different D-**** registrations.  However I am unaware if the hex/registration stays consistent with each use as the example you have given is different from the hex you picked up
3FF23B,D-MRHH,194,Tecnam P92 Echo
26th
3D1400,D-EFVC,,Piper PA-28-181 Archer III,Frankfurter Verein für Luftfahrt
3D1C8D,D-EJBH,593,Robin DR 300/108 2+2
3E38B3,D-IMRB,LJ-1900,Beech C90GTi King Air,Eisele Flugdienst,
Nothing on the others and mil tac done
Many thanks
Morning falcon
3EC391,D-KPAF,44513,Scheibe SF 25 C Falke 2000
3EF7B1,D-5914,1823,Grob G 102 Astir CS 77
Nothing on the other unknowns
Many thanks
26th continued
3FF4D5,D-MSWK,026,Tecnam P96 Golf,
7100BF,HZ-AK31,61595/1414,Boeing 777-3FGER,Saudia,
Many thanks again
#6996
Seems to be a bug at planefinder:
3FEC98  DMJCT                    D-MJCT  FDCT    in our db
until now I got DMPCT always with hex 3FF171
The d/b shows 3FEC98,D-MJCT,07-11-02,Flight Design CTLS
D-MPCT has been used by
Flight Design CT c/n 99-06-03-56 now D-MYHK
Flight Design CT Supralight c.n E-09-02-11 now D-MLLE
Flight Design CTSW c/n 05-01-04 now D-MPCD
Flight Design CTSW c/n 07-01-16 now D-MQCT
It may be either of these miscoding its previous ID or it may be a new D-MPCT
#6998
I posted 3FF171 DMPCT
planefinder has D-MPCT with hex 3FEC98, which is false as 3FEC98 is D-MJCT
pictures at strforum unveil, that D-MPCT is currently a CTSW
D-MQCT can be ruled out for miscoding, as it is recurring guest in my list. Also D-MPCD as I have seen it in Heidelberg area in April 2016 with correct hex. D-MLLE last seen 2014 also with correct hex. D-MYHK, as this one is the oldest one and a CT not a CTSW it can be ruled out for miscoding too.
Therefore I presume I got new CTSW which will be sold (sooner or later) and get another D-M*** reg.
Maybe we could add it in as test reg of FD several/various ultralight using this reg/hex.
I will add it in as a test registration Ingo
Thanks!
Yesterdays unknowns as soon as I'm in Heidelberg.
Morning Terry, many thanks
Afternoon Alan,
Not populating :
488232
Flight Id : SP-AST
Nothing else.
JAF99P : LFPO-GMFO
Afternoon Ian
488232,SP-AST,525-0495,Cessna 525 CitationJet CJ1
Many thanks
Blueboy
Hi Alan, just out of Belfast is Cessna 560XL c/n 560-5218  hex AC76CD
J.D
