0 Members and 83 Guests are viewing this topic.
#7036
Afternoon Alan,
Getting a good range today :
3E31D8
Flight ID : SCR357
D-IKBO C525 c/n 525A-0357
Routing : NZAA-NZNR !
Some wires crossed over there Ian!!
Good Afternoon / Evening Alan, unknowns Aug 31st:
3C5EFD (3x) nothing more
3E388C  DIMPO (2x) finally: https://forum.luftfahrtclubbraunschweig.de/viewtopic.php?t=4882
3E61FC  DKCHO http://www.onlinecontest.org/olc-2.0/bitterwasser/flightinfo.html;jsessionid=304455DE407ACC1C225A24FB90CE99BD?dsId=4944664  http://www.greenspeedcup.de/de/news/gsc-2015/ https://en.wikipedia.org/wiki/Technoflug_Piccolo
MILs:
   3E8039  LANCE1                                                         2016/08/31 06:51:34
   3E8039  LANCE1                                                         2016/08/31 07:53:06
* 3E9776  LK01B                                                          2016/08/31 12:28:56
* 3E99CA  GAF114                                                         2016/08/31 06:22:53
3FF292  DMPPI no further information (was a Remos GX-NXT for sale)
3FF362  ZZZZZZZZ still nothing more
3FF3E6  DMIBH no luck with the details
3FF427  DMVGT (2x) still no luck
3FF464  DMXOO same as above
3FF510  DMHVN still no luck
A0E3CA  N1567D (2x)  http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N1567D
Regards Ingo
Evening Ingo,
3C5EFD does not decode, in between code blocks
3E388C,D-IMPO,LJ-1718,Beech C90A King Air details now on LAAS ex PH-KBB
3E61FC,D-KCHO,078,Technoflug Piccolo B
A0E3CA,N1567D,7789,Cessna 195A,Southern Aircraft Consultancy Inc Trustee
Nothing on your others and mil tac added
Many thanks
Alan,
Just come over the top and clearly seen against the night sky :
B-3143 EMB 190 c/n 19000717 of Tianjin Airlines with flight ID of GCR3143. On delivery or what ?
paul tricker
* A06068  N123SA                                                         2016/09/01 16:53:58
N123SA  Piper PA18-150    181372  Southern Aircraft Consultancy Inc Trustee
Paul
Kenny
#7044
8815B4  HS-EMT  Cessna 550 Citation Bravo c/n 550-0935  ex EI-PAL  op H S Aviation
880461  HS-ACA  Cirrus SR22T c/n 0118 ex N118TH  op AC Aviation
882E01  HS-KPA  Falcon 2000S c/n 707 ex F-WWGG  op King Power International
Kenny
ANRB 3km north of VTBD
CYYZGUY
#7045
40" LED Monitor
40" LED Monitor
X
#7046
New unknown Saudi code should be HZ-AK32 B773 Saudia 61591/1421
* 7100C0  SVA820   OERK-WIII                                             2016/09/02 02:49:11
X
Many thanks Kenny.  HS-KPA is already in the d/b
#7049
x
7100C0,HZ-AK32,61591/1421,Boeing 777-3FGER,Saudia
Many thanks.  The Puget Blog has not been reliable for a time but I note that it was at least updated last night for first time since 22nd August.
