0 Members and 228 Guests are viewing this topic.
diddyboy
Hi Alan
One more route update
QTR1437 OTBD - HDAM
QTR1438 HDAM - OTBD
Neil
Many thanks Neil.  BTW now OTHH.
CYYZGUY
40" LED Monitor
40" LED Monitor
CYYZGUY
Some more ground returns
Flight ID: BMN72
Mode-S C1E845
Wildlife Control CYYZ
Flight ID: BMN74
Mode-S C1E847
regards,
Jason
40" LED Monitor
40" LED Monitor
Kenny
Quote from: Runway 31 on May 24, 2015, 09:20:54 AM
Hi Kenny,
Many thanks, much appreciated.
When you update do you use Update All Records as your update option.  HS-LFH is not in the database and if you use this option to update your database it should not be there.  Its not in my Navdata.
I chose 'do not update manually changed record'  probably this is the case.
Kenny
ANRB 3km north of VTBD
In that case Kenny could I suggest you delete it manually from the d/b
CYYZGUY
#743
WJA2601
No Routing
https://flightaware.com/live/flight/WJA2601
WJA546
No Routing
https://flightaware.com/live/flight/WJA546
WJA1680
No Routing
https://flightaware.com/live/flight/WJA1680
Two more ground returns
BMN73
Mode-S C1E846
RED5
Mode-S C1E801
Crash, Fire, Rescue CYYZ
regards,
Jason
40" LED Monitor
40" LED Monitor
M
NAX8YB   ENBO   LTAI
NAX8749   LTAI   ENBO
NAX7LZ   LGSA   ENBO
JTG961   EFHK   LGKR
JTG962   LGKR   EFHK
JTG917   EFHK   LGSA
JTG918   LGSA   EFHK
Michel
Alan,
CND712 LGIR-EHAM iso LGRP-EHAM
Michel.
CYYZGUY
Hi Alan, some more ground returns for you.
OPS1 (C1E84A)
Airside Operations CYYZ
INSP35 (C1E7E6)
Runway Inspection CYYZ
MTC60 (C1E83D)
Airport Maintenance CYYZ
MTC31 (C1E83E)
MTC25 (C1E7E7)
regards,
Jason
40" LED Monitor
40" LED Monitor
