0 Members and 82 Guests are viewing this topic.
silverjet102
Good afternoon,
Please find attached SunExpress winter 16/17 callsign lists.
Kind regards
Cameron
orkney
Hello Dave and Cameron
Thanks for that couple of Alpha jets.
I will add that Sunexpress ones at some point today.
Thank you both again
Andrew
Andrew,
For info, the SXS and SXD route info are two of those I have already compiled and am going to send to you
orkney
Hello Alan
Ok, I will leave them until I get them from you.
Andrew
I will send them shortly Andrew
Good morning Andrew, unknowns of Oct 18th:
3D2D75  DEPLT received again, still nothing regarding the details
3D4D4C  DFBNG (2x) first received about a week ago, still no luck with the details
Two MIL/TAC of GAF:
* 3F8BD2  JUDGE1                                                         2016/10/18 11:55:22
* 3F8BD5  GHOST31                                                        2016/10/18 09:31:39
3FF524  DMEYK (2x) no luck with the details
Regards Ingo
orkney
Hello Ingo and Terry
Thanks for them. They are added/amended.
Andrew
Michel
Andrew,
EWG4018 EDDH-LFPG
VKG1453 GCLP-ESMS
EXS656 LCPH-EGNX
EXS820 LGRP-EGCC
CND1395 GMMX-ESSA
Michel
orkney
Hello Terry and Michel
That should be them done.
Andrew
orkney
Hello Terry
That is all of them done, Including all the EI-FX* ones.
Andrew
orkney
Hello Terry
That is that ones added and amended.
Andrew
superspotter
Hello from Lagos;
Hexcode 03843C is TU-TSL Air Cote D'Ivoire DH8D. Thought I may have given you this one before but it's blank in Airnav.
regards clive.
orkney
Hello Clive
Thank you for that one, It wasn't in the main database either.
Andrew
superspotter
Hello again from Lagos;
Hexcode 040021 is ET-AOK Asky 737. Im sure I have given this one before and Alan mentioned it was miscoded? Anyway, it is still blank in Airnav.
regards clive.
orkney
Hello Clive and Terry
Thank you for these ones.
Clive -  ET-AOK had only been entered as its 040011 code, It should work now though
Andrew
