0 Members and 121 Guests are viewing this topic.
Good morning Alan, Mondays unknowns:
MILs:
* 3E9D14  GAF191                                                         2016/10/24 09:22:42
* 3E9D14  GAF191                                                         2016/10/24 12:57:29
* 3EA127        2016/10/24 09:53:58
* 3EB8F9  GAF711                                                         2016/10/24 07:50:34
* 3FB885  GAF633                                                         2016/10/24 12:49:00
* 3FBCC6  GAF789                                                         2016/10/24 10:27:35
AF014D  RCH836 US MIL
Regards Ingo
Many thanks Ingo.
Mil tac added
AF014D is thought to be KC135R 58-0023 which was noted using the same call sign the day before using its correct hex of AE014D
Many thanks
M
IBE6800   RJAA   LEMD
IBE6801   LEMD   RJAA
ADR55V   EETN   EYVI
ADR56T   EYVI   EETN
NTJ4854   ESSA   ESNG   via ESNX
German mil tac:
* 3EBCF4
* 3F7C1B
Morning Alan/Terry,
You could try this for the German register. It's not fully up to date as the guy who use to compile it no longer does it. It doesn't give owner/operator details.
http://coptercrazy.brinkster.net/search/d-e_index.asp?Search=D-
Hi Terry,
I can only presume that the med call aircraft are managed by MHS Aviation and flown on their behalf and will keep an eye out for them to see what flight ID they use.
I normally use the owner as registered with the FAA and or operator where required except for airliners where I don't use the leasing company they belong to when they are being operated by an airline.  That way as you state the logo aligns with the flight ID.
Many thanks
Hi Ian,
Thanks, it hasn't been updated for a couple of years.  The site owner gave it up as he was getting so much grief from users of the site.
Cheers Alan,
Better than nothing, I suppose.
Michel
Alan,
AZG201 UBBB-EHAM iso UBBB-LOWW
ETD170 KLAX-OMAA
SAS557 ESSA-EHAM iso EKCH-KDFW
Michel
Good evening Alan,
the following MIL hasn't populated:  * 3FB885  GAF633
Please check if it was entered correctly.
Many thanks Ingo
My old eyes saw the first 8 as B Ingo,
Now added in correctly
Many thanks Terry
ACE721,N930RA,1146,SCOCATA TBM 930,Transatlantic Deliveries Trust
falcon_nl
Short list from today:
4D036D callsign LXAIM
3DD464, D-HARK, 7452, BK17, Heli-Service GmbH http://www.dgualdo.it/wpmain/?tag=d-hark
