0 Members and 21 Guests are viewing this topic.
Afternoon Ingo
My database details that T7-BBB became SP-YYG in May 2016.  I checked the website you sent the link to and under team I note that the photo there was from 2009.
http://www.eurodemobbed.org.uk/locations.php?location=3141 shows the aircraft noted as SP-YYG in May last year at Rotenburg Airfield the same airfield as your link.
Agree with your comments on the A321 and have made the change as you detail
Many thanks
Afternoon Ian, many thanks
For info EC-JBK was parked in Kaunus Lithuania from 23/10 but good to knows its back in service
Afternoon Alan,
Looks like a typo.
ISR181 and the return ISR182 are both in the d/b as routing LLPG-LEMD and return . It should be LLBG-LEMD and return.
I feared that you would came up with these details about T7-BBB. The question is now: which (YAK-5X) aircraft is using this false reg now. As I said: I got this hex 5 times since July 2016. Three times with flight id T7BBB. Maybe they got another  one ready and up in the air and have just transplanted the mode s avionics equipment.
Seems that we have to wait until time tells us, if it is a new one or perhaps still SP-YYG using false hex and misleading flight ids.
#8406
The way I look at it Ingo, if they have the transponder wrong with the hex it is just as likely that they have not changed its flight ID
I also found this which indicated the reregistration http://www.ukserials.com/prodlists.php?type=1207
I found the same website and although I had my doubts about the YAK I posted I posted it anyway, due to a slight streak of lazyness and to see if you will come up with the same infos I found.
Thanks! Ingo
Michel
Alan,
EZS85TP LSGG-EHAM
TCX75WF EGAA-LBPD
TRA6508 GCFV-EHAM
Unknown: 45CD35 DNU901
Michel
jim_stockwell
Good evening Alan and a happy New year
Although I have not updated my database for a couple of days the following either did not populate or was missing some info.
Hex 4535CD flight I/d DNU901
and earlier D-CHIP passed overhead which according to LAASI is Citation 525B-0498
Jim
Many thanks Michel
45CD35 DNU901 inbound EGNX and is OY-CIU miscoding, should be 458D35
Evening Jim and Happy New Year
D-CHIP updated
In my range between 17:07 and 18:11 UTC (FL180 --> FL180).
Any idea were it came from?
Thanks Ingo
CYYZGUY
40" LED Monitor
40" LED Monitor
