0 Members and 34 Guests are viewing this topic.
Xon
4891B9 SP-ENQ B738 c/n 29036
Kenny
#886
Quote from: Runway 31 on June 02, 2015, 03:07:32 PM
Kenny,
HS-KAB is in the database as a C208.  Just downloaded the Navdata and its a C208 in it as well.
In my DB explorer all other field are updated to the correct info except AT field.  Manually update correct it.
Yesterday unknown,
* 3B7FEF        2015/06/02 16:23:11
7503C1 is 9M-AJM
Kenny
ANRB 3km north of VTBD
Thanks Xon, already in d/b
Hi Kenny,
Thanks for that, amended.
Cant find any details on your French mil
Northern Watch
Hi Alan
One that did not populate from earlier today:
34508E / c/s ECMGT.
Keith
Morning Alan, unknowns from yesterday:
3C4B97 nothing more
3E350F nothing more
3FF093  DMUAW http://www.abpic.co.uk/photo/1344155/
3FF0D2  DMBKM still no luck with the details
3FF1FD  DMYXB http://www.mst-aviation.nl/viewtopic.php?t=37200 No details there, but maybe somebody can figure out the type from the picture.
468897 received two times: http://www.flightradar24.com/data/airplanes/sx-bdw/
8A04FD  SXI1509 http://www.flightradar24.com/data/airplanes/pk-ksf/
MILs:
  3E811B  GAF127                                                         2015/06/03 11:36:29
   3E9C09        2015/06/03 06:58:31
   3E9C09  TA64                                                           2015/06/03 10:13:18
   3E9C09        2015/06/03 15:01:09
* 3EB24F        2015/06/03 07:09:50
* 3F4B06        2015/06/03 13:11:56
* 3F4CA2        2015/06/03 13:53:00
   3F5254  GAFM51                                                         2015/06/03 09:12:35
   3F59A4  GHOST                                                          2015/06/03 08:23:52
* 3F6294  STRIKE                                                         2015/06/03 13:33:08
* 3F8201  GAF132                                                         2015/06/03 09:42:12
* 3FA1B6  EAGLE                                                          2015/06/03 13:23:05
* 3FA78B        2015/06/03 07:23:58
* 3FA78B  SPOOK2                                                         2015/06/03 08:11:33
Regards Ingo
Unknowns from Tuesday June 2nd:
093B9F no country allocation
12FC8B nothing more
1C4ED0 nothing more
20111C  STQ99B that's one H of a decoding error (corrupted packet) of this airframe: 3E391C  STQ99B
380FF6 nothing more
45A9A1 nothing more
4BD18C nothing more
4CAB0C was EI-FCE no indications, that it is active again
780DE4  CES599 you have entered and posted it after I received it...
A64DD3  N505PL http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N505PL
US MILs I guess:
   AE16E3  WARHAWK1                                                       2015/06/02 08:11:13
   AE16E5  WRHAWK05                                                       2015/06/02 08:22:01
   AE1710  WRHAWK06                                                       2015/06/02 08:21:55
German MILs:
* 3E811B  GAF127                                                         2015/06/02 07:21:56
* 3E83A1  GAF757                                                         2015/06/02 10:33:09
* 3E9C09  TA64                                                           2015/06/02 07:01:44
* 3E9C09  TA64                                                           2015/06/02 11:09:59
* 3E9C09  GAF646                                                         2015/06/02 11:30:39
* 3E9C09  GAF646                                                         2015/06/02 14:11:46
* 3F59A4  ATTACK                                                         2015/06/02 13:27:12
* 3F5B2D        2015/06/02 16:56:09
* 3F6AB7  NOBLE                                                          2015/06/02 09:06:17
   3F9158  GAF667                                                         2015/06/02 10:15:36
Thursday, May 14th:
0BAAC1  THY20F TC-JVA with a dodgy Transmitter...
30048D nothing more
344406 nothing more
3C6412 notthing more
3D1F87  HRE36H posted a couple of days ago
3D8F31  DGAMB http://planefinder.net/data/aircraft/D-GAMB was eyeballed in 2015 by a member of flugzeugforum.de
3FEA82 D-MIIN no luck with the details
3FEB2B  DMYMS Hex decodes D-MOLG was a Flight Design CT Supralight that crashed in 2013. airframs has it as Flight Design CT-SW now.  D-MYMS:  http://www.aviationfanatic.com/ent_show.php?ent=5&AC_Regno=D-MYMS
3FEEF6  DMCTM Flight Design CTLS latest Mk1EB I found is from 2011
3FEF2C  DMSJL http://www.jet-scout.com/Flight+Design-CTK-for_sale_955.html
3FF0A4  DMGLI http://www.abpic.co.uk/photo/1344143/
3FF2FD  DMCSK http://www.airplane-pictures.net/photo/563081/d-mcsk-private-platzer-kiebitz/
3FF388  DMKTP http://www.abpic.co.uk/photo/1472540/ (there must have been a meeting for this type)
400C5E no active airframe found, two previous entries found for this reg.
49D369  TVS739T OK-TSI already in db I guess
4BAACB nothing more
506E5E  FLYCOM2 after a long time I received this one again
A2DC97  N2838G http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=N2838G
Hi Keith,
Its in todays download, probably entered after you picked it up, out of Helsinki on delivery to Volotea
34508E,EC-MGT,55066/5054,Boeing 717-23S,Volotea
Hi Ingo,
Yesterday
3C4B97 doesn't decode
3E350F decodes to D-ILHF unknown to me
FF093,D-MUAW,,Aerospool WT-9 Dynamic
3FF0D2 D-MBKM still unknown and around 2 years since first picked up
3FF1FD,D-MYXB,,AutoGyro Cavalon
468897 SX-BDW B733 already in d/b
8A04FD,PK-KSF,AT45 already in d/b
Thanks Alan, MIL/TAC is processed later?
Ingo,
2nd June
380FF6 unknown to me
45A9A1 decodes to OY-JMA not on register
4BD18C decodes to TC-TLL unknown to me
4CAB0C decodes to EI-FCE not current
780DE4 B-16979 A321.  With your receiver being so near XFW the only way I can beat you to it is to have them in before they are delivered
A64DD3  ASTR N505PL registered 1/6
I believe the US mil to be F-16's but don't know if those are real or tactical codes but if real they are unknown to me.  The german tac codes added
The mil tac from 2nd have been done, forgot to mention them
X
This is the same aircraft EP-MMH A346 c/n 391 Mahan Air one correct code and one miscode already!
* 733588  IRM060   OMDB-OIIE                                             2015/06/03 12:28:32
* 7335A8  IRM061   OIIE-OMDB                                             2015/06/03 10:04:15
X
Ingo,
14th May
30048D unknown to me
344406 unknown to me
3C6412 doesn't decode
3D1F87 D-EKEP already in d/b
3D8F31,D-GAMB,D-GAMB,Piper PA-34-200T Seneca II has been around since 1993
3FEA82 D-MIIN unknown to me
3FEB2B,D-MYMS,,Flight Design CTSW
3FEEF6,D-MCTM,,Flight Design CTLS
3FEF2C  D-MSJL already in d/b
3FF0A4,D-MGLI,,B&F Funk FK-14 Polaris
3FF2FD,D-MCSK,,Platzer Kiebitz
3FF388  DMKTP Platzer Kiebitz nice aircraft but not a lot of engine!
400C5E not current
49D369 OK-TSI B739 already in d/b and seen here in Murcia last Wednesday
4BAACB decodes to TC-JVK unknown to me
506E5E unknown to me
A2DC97  N2838G P28A already in d/b
Thanks X, wonder if it will be the only one.
