0 Members and 31 Guests are viewing this topic.
3F727C is now known, its not tactical but a new A400 on delivery
3F727C,54+08,046,Airbus A400M-180,Germany - Air Force
Morning Terry, many thanks
X
Four unknowns, the second one also seen twice in December and is ADSB equipped and seems to be a reuse of a hex used by Yakutia B737 VQ-BEO (which went to US). Another Italian code on a RSD f/n and the strangest one is the last UK one with RA67242 c/s (an old Let410 reg), is it a new Canadair?
* 42449F        2017/02/01 02:31:30
    42494E        2017/02/01 09:36:07
    30040D  RSD064                                                         2017/02/01 13:47:41
    43E943  RA67242                                                        2017/02/01 12:45:12
X
X
42449F is VP-BUY miscoding, now entered in the d/b as such.  I believe it is a one box miscode and it will probably return using its correct hex of 42429F
42499E no information
30040D no information
43E943 was M-SSSR which went to Russia in January so it should be 43E943,RA-67242,9406,Bombardier BD-700-1A10 Global Express,(Miscode hex of M-SSSR)
X
I assume you have already entered RA-67242 into DB as its correct code 1506AA as well as its M-SSSR miscode.
X
Will do X as I presume it will change in time
Thanks again Terry
Since Cessna was taken over by Textron I have made all the new build aircraft Textron Aviation as they seem to chop and change I suppose depending who is doing the registering with the FAA.  Sometime they are shown as Cessna and sometimes Textron.  The same with Beech.
Evening Alan, one unknown MIL from HD area today:
* 3E9B1F  VADER12                                                        2017/02/01 08:47:17
* 3E9B1F        2017/02/01 09:24:26
Evening Ingo
Your mil tac added
Did you note my earlier post advising your mil tac from yesterday was actually a new A400 on delivery to the German Air Force
no I haven't noticed your update about the A400. I've checked my MyLog.db and it seems, that it has landed at Wunstorf Air Base.
Yes  Ingo it is with LTG62 at Wunstorf
Michel
Alan,
IBK9WT ESSA-GCLP
RAM816C GMMN-EKCH
Michel
