0 Members and 26 Guests are viewing this topic.
#8910
There is a deal between DLH and BER in progress. The fact that EWG is a DLH daughter might explain the EWG flights done by airberlin airframes. I guess that there are many other movements/transfers about to happen in the nearer future.
The OY-GSA you stated is the older PC-12/45 CN:421 one. There was a younger PC-12/47E cn: 1065, that was just canceled from danish register. This could be the one I possibly got on its way to the new operator. But time will tell.
Ingo.
PC12 c/n 1065 became D-FDHR last May
Michel
Alan,
BER7382 EDDL-MDPP
CFG2198 EDDF-MUVR
CFG2226 EDDF-MDPC
IBK2LP ENGM-LEMG
RYR2VA EETN-EGSS
VKG1315 GCTS-EFHK
New owner:
4841C1 PH-HBW C172 Lalmy Aviation BV
484730 PH-VRW C150 C Quist
Michel
No Idea Terry but the J is added in
Good morning Alan, Sundays unknowns:
401080 (6x) no active airframe found. A little too many entries for bad packets received.
459E61  OYGSA agian, must definitely be new one with this reg/hex tie up.
Regards Ingo
M
SCW258U   ESSB   ESNU
SCW267P   ESNU   ESSB
FIN4301   EFTU   EFKT
FIN4302   EFKT   EFTU
FIN4303   EFTP   EFKT
FIN4304   EFKT   EFTP
KAR3519   UUEE   MDPP
KAR3520   MDPP   UUEE
Cheers Terry, I don't use Edge but use Chrome on W10
Morning Ingo,
401080 decodes to G-DKMK which is not allocated by CAA.  The holder of the hex/registration is an R44 which is now I-MWII.  Without a flight ID we have no way of knowing if it is this one miscoding its old hex
459E61 OY-GSA became D-FDHR last year and I have no information on a new one.  There have been  two aircraft with the registration both PC-12's.
c/n 421 which is now N888GW and c/n 1065 as above, photo here in December http://www.oy-reg.dk/register/6508.html as D-FDHR.  The info on the link states it was cancelled from the  register in January.  Is it the same one miscoding its old ID or is it another new one with the same hex registration  combination we shall need to leave for time to tell but I can find nothing on a new one.
M
Quote from: Runway 31photo here in December http://www.oy-reg.dk/register/6508.html as D-FDHR.  The info on the link states it was cancelled from the  register in January.
Actually the link states that D-FDHR was registered as OY-GSA in year 2017. There's no cancellation year given.
Compare for example to this (2009-2016): http://www.oy-reg.dk/register/5779.html
#8921
Thanks M, my mistake as I misread it as it states year of registration - cancelation.  I presume therefore that it has reverted back to OY-GSA from D-FDHR since the photo was taken in December . I note it was updated 4/2 on http://hwww.oy-reg.dk/news/
459E61,OY-GSA,1065,Pilatus PC-12/47E
Found this on the internet D-FDHR up for sale by a Danish company so guess they re-registered it http://europeanaircraftsales.com/media/40982/D_FDHR_Spec_Sheet.pdf
Morning Alan,
EZY27YM : EGGD-LEAL
JAF88Y : LEAL-EBCI
TVF3045 : GMFF-LFPO
RYR5579 : EGPH-LEAL
VLG1412 : LEAL-LEMH
TVF91TA : LFLL-GMAD
RYR10MY : LEAL-EDLV
MON522 : EGCC-LEAM
EXS041A : EGNM-LEAL
TRA4U : LEAL-EDDM
RYR8113 : LIRA-GMMX       Needs Recycling.
RYR2845 : LFOB-GMMW      Needs Recycling.
Incidentally, I appear to have a new layout for the website/forum this morning.
Morning Ian, the majority just needed re-cycling.  Yes new layout
QuoteThanks M, my mistake as I misread it as it states year of registration - cancelation.
Well, at least you are not alone. As I did the same misinterpreting. Considering the activity of OY-GSA the past couple of days the aircraft could be already sold.
New layout doesn't work proper on smartphone browsers. So they should have done some more testing before launching it.
