0 Members and 19 Guests are viewing this topic.
Afternoon Terry, thanks again
Afternoon Ian, A6-EML already marked as WFU Stored
Cheers Terry, can only presume the additional L was there previously
#9095
Evening Alan, I just got this one in HD:
3C48EA  BER697Y D-ABGJ ex. OE-LNE of Niki.
Airbus A319 MSN: 3415
One of the BER/EWG share planes as far as I could figure out. Recently it flew BER flights.
Many thanks Ingo, was waiting on it making the change but hadn't noted it
Back in business since today. Flight from EDDL to LSZH and back. To Rome after that rotation.
Thanks for the information Ingo
silverjet102
Not sure if you can update but the following Airport names are missing.
OTHH - Doha Hamad International Airport
VTBS - Bangkok Suvarnabhumi Airport
OMDW - Dubai Al Maktoum International Airport
Kind regards
Cameron
Good morning Alan, Sundays unknown:
3FF56C  DMEAX unfortunately still no luck with the details.
Hello Cameron,
which version of ANRB software do you use and how old is your navdata.db database file?
These three airports are definitely in the navdata.db some of them at least for a couple of years.
M
KLM1399   EHAM   ULLI
KLM1394   ULLI   EHAM
IBK4KA   LEAL   EFHK
SCW97D   ESNZ   ESSB
EDW1329   ENTC   LSZH
ISR5679   LLBG   EFRO
ISR5680   EFRO   LLBG
JAF9701   EBBR   EFKT
JAF9702   EFKT   EBBR   via ENTC
NTJ667   ESUT   ESSA   via ESNV
0641D9 , 5N-BUJ , B735 , Boeing 737-5L9 , Air Peace , 28721/2856
silverjet102
Hi Ingo,
I went back to version 4.03 as the others were very unstable and unpredictable.
Cameron
#9104
Hi Cameron,
As stated by Ingo, the names are in the d/b and show on my screen.  All I can advise is to upgrade to V5 or later if you don't have them and to download the airport table as they are there in it.  OTHH was added before the airport even opened.
There are no stability issues with V5 and V5.00.72 can be got from here http://www.airnavsystems.com/download/ANRB/ANRB50072Setup.exe
If you don't want to upgrade all I can suggest is that you go onto Wikipedia and get the required info and add it into your airport table manually.  If you require I can post the information held for each airport.
