0 Members and 15 Guests are viewing this topic.
Some EWG/GWI routes:
EWG62H EW1075 EDDP EDDL
GWI57F 4U9041 EDDT EDDL
GWI67C 4U11 EDDT EDDK
GWI9727 4U9727 EPKT EDDL
Morning Terry, thanks again
Morning Ingo,
The issue I have with T7-BBB YK52 is that my d/b shows that it became SP-YYG in May 2016 a year after that post you give the link to and these links http://www.ukserials.com/prodlists.php?type=1207 and http://www.eurodemobbed.org.uk/locations.php?location=3141 shows this to be the case for c/n 800708  The question therefore is this a new T7-BBB which in that case would make it an unknown or is it SP-YGG using a miscode and its former flight ID.  I would think it is the latter as it operates or was noted operating out of Rotenburg which would make it within your coverage area and will add it to the database as SP-YGG.  280016,SP-YGG,800708,Yakovlev Yak-52,(Miscode)
Nothing on the others other that being able to confirm that the hex ties up with the registration shown
Mil tac added as are the routes
Many thanks
what is the hex of SP-YGG please?
I have no idea what it should use Ingo
I went through my LOG files,
and the first reception of 280016 was July 30th 2016. Since then 5 further times received, two times with flight id T7BBB, all other cases no flight id at all. Flight id SPYGG was never received. I aggree that it is highly possible, that SP-YGG is still using all old settings.
Thanks!
Good morning Alan, Saturdays unknowns:
3CC139  DCAMB received again
3D1954  DEHVO https://planefinder.net/data/aircraft/D-EHVO http://www.texelflyin.nl/participants-list/
3FECCC  ZZZZZZZ no further information
3FF426  DMSVV (2x) still no luck with the details
3FF4E9  DMHCY still no luck with the details
3FF55F  DMGIY no further information
4CA55B  EIFMI https://www.planespotters.net/airframe/Airbus/A330/1651/EI-FMI-Intrepid-Aviation-Partners-(IAP) I would suggest: On its way due South-East to become TC-???
Have a nice Sunday!
Regards Ingo
Morning Ingo,
3D1954,D-EHVO,081,Piaggio P-149D
4CA55B,EI-FMI,1651,Airbus A330-343E,Intrepid Aviation no info on its new ID
Many thanks
Kenny
9M-AJY, 9M-NEO   op is AirAsia  (no space in between)  to be consistent with rest of the fleet.
B-16726  op is EVA Air
HS-BBW  op is Thai AirAsia
HS-EMG  op is H S Aviation
HS-EMT  op is Mjets
HS-PPO, HS-PZG  op is Bangkok Airways
HS-BCD has been recoded to 88082D
Kenny
ANRB 3km north of VTBD
Good morning Alan, Sundays unknown:
3FF2D6  DMMSE still no luck with the details
Regards Ingo
#9251
Morning Ingo.
Still nothing on D-MMSV
I received an update to my database yesterday and now have the details of 2 of your Friday unknowns
3CC139,D-CAMB,31-155,Learjet 31A ex D-CPRO
3E4A50,D-ITIM,42000017,Hondas HA-420 Hondajet,Rheinland Air Service
AoD
company update:
49D018   OK-SLS   Silesia Air
49D363 is OK-KAL (not OK-LAL)
Morning Alan,
GMI7806 : EDDN-GCFV
RYR92NR : EGSS-LEAL
VLG3220 : LEBL-GCTS
TUI3AG : LFSB-GCFV
MON26VC : EGCC-LEMG
RYR77WU : EGCC-LEAL
TRA30A : LEAL-EHAM
IBE3307 : DAOO-LEMD
