0 Members and 14 Guests are viewing this topic.
#9526
Hi JD,
I had hex 4D0241 on my box earlier on a GAC flight ID.  This was used previously by LX-FGL until de-registered in 2014 but I have it as a miscode used by OE-FZB.  I have no idea what was in at Glasgow.  OE-FZB should use 440590 and OE-FWF should use 4405DA.
Just received a post on EGPF forum stating its OE-FWF miscoding into Glasgow.  Both aircraft are from the same company so maybe been a box swap.
#9527
Another unknown from HD area:
34535A  VLG902P on delivery and still in the air: https://xfw-spotter.blogspot.de/2017/03/a321-231sl-vueling-d-ayaq-ec-m-msn-7599.html
https://www.radarbox24.com/flight/VLG902P
Thanks Ingo, already added along with DKH9472 also out of XFW
The Vueling has now populated here in Heidelberg.
Many Thanks!
Blueboy
Hi Alan, thanks for clearing thinks up - and you thought military hex's were a problem :)
J.D
Michel
Alan,
AUA37A LOWW-EHAM
DLH2JW EIDW-EDDM
DLH947 EGCC-EDDF
EWG1BR EGLL-EDDL
EXS110 LTAI-EGPF
GWI1E EDDH-EGCC
IBK541B EHAM-EKCH
KLM94L EKYT-EHAM
KLM997 EHAM-EGLC
LOT2MF EGLL-EPWA
TCX531 LTAI-EGPF
TCX86CN EGCC-LCPH
Michel
Evening Terry, thanks again
paul tricker
Almost done
A7059E   N5511A      13/03/2017   12:53:46
Maule M-7-235B / 23076C / Paul W Buller
A7253F   56GZ      17/03/2017   09:59:46
Vans RV10 / 41663 / Michael E Wright
A7C83D   N600LD      16/03/2017   17:40:06
Aeropilot S R O Legend 600 / 1531 / OC Aviation Holdings
A80155   N615AD      13/03/2017   15:07:07
Piper PA-12 / 12-229 / Douglas L Hill
A89732   N6525C      17/03/2017   10:01:59
Beech P35 / D-6871 / Eric Barron
A8B9FD   N661X      22/03/2017   11:05:52
ONEX / ONX0140 / David J Knutson
A8D1C9   N66786      19/03/2017   12:24:06
Cessna 150M / 15076279 / Erik S Tu
A8EC45   N674TH      17/03/2017   08:04:42
Kaman Aerospace K-1200 / A94-0035 / Timberline Helicopters
A8F589   N6768Y      18/03/2017   10:54:10
Piper PA-23-250 / 27-4100 / Piper Aircraft Inc
A91B8E   0N686X      14/03/2017   13:56:39
Fred Weaver HR-11 /  207 / Barry J Halsted
A97A24   N71EM      19/03/2017   13:20:01
Schempp-Hirth Discus 2A / 6 / High Flight LLC
A9BE63   N727JP      13/03/2017   02:23:21
N808MA / Cessna 208B / 208B2427 / Wells Fargo Bank
(N808MA was using the hex & callsign from its previous id. Eyeballed several times each day)
A9DA68   N734FD      13/03/2017   16:23:23
Cessna 172N / 17268813 / Daniel R Johnston
Paul
Good morning Alan, Wednesdays unknowns:
MILs only:
* 3E9EF8  GAF639                                                         2017/03/29 07:35:28
* 3E9EF8  GAF639                                                         2017/03/29 09:52:51
* 3F705B        2017/03/29 12:19:12
   3F705F  SPARK3                                                         2017/03/29 07:18:57
   3F705F  ACES1                                                          2017/03/29 11:48:43
   3F705F        2017/03/29 16:25:31
Regards Ingo
paul tricker
Last lot (unless you want all the ones that are listed as unallocated!)
A9E56C   N737DW      13/03/2017   15:55:49
Cessna 172N / 17269347 / MH Aviation Inc
AA868B   N7778U      15/03/2017   11:33:03
Cessna 172E / 17251778 / William G Drazil
AAC21B   N7922K      13/03/2017   14:57:05
Beech S35 / D-7456 / Flyings Better LLC
AB08BE   N81TT      13/03/2017   18:12:19
Vans RV7A / 73057 / David A Pizzo
ABD9A0   N8627P      18/03/2017   08:20:25
Piper PA-24-260 / 24-4101 / Patrick Reilly
ABE154   N8649P      19/03/2017   16:26:37
Piper PA-24-260 / 24-4092 / J&S Aviation Services LLC
AC8F63   N9081D      14/03/2017   08:22:20
Robinson Aircraft Manufactures Test registration
AD0B02   N94CA      22/03/2017   08:39:39
Cessna 172G / 17254435 / James W Young
AD1040   N9405S      18/03/2017   14:01:56
Beech V35 / D-8010 / Dean R Hackbarth
AD2496   N946MS      13/03/2017   07:49:19
American Champion Aircraft 7ECA / 1411-2015 / MT San Antonio College
AD8B68   N972DK      19/03/2017   14:42:49
Vans RB-8A / 82258 / Jeffery D Koehler
AD9AFA   N976LS      17/03/2017   21:01:05
Vans RV-6A / 22385 / Lawrence B Smith
AD9D33   N97661      13/03/2017   12:41:14
Cessna 182Q / 18267162 / Gravity Productions Inc
ADAF3B   N981DW      15/03/2017   13:23:20
Airbus Helicopters AS350B2 / 8132 / Raven Aviation LLC
ADC7C8   N9872E      19/03/2017   15:22:03
Cessna 182R / 18268458 / James Mckoane Enterprises Inc
ADF5A7   N999SE      16/03/2017   09:50:42
Gulfstream G-IV / 1315 / Regdalin Aviation LLC
ADF62D   N999XP      13/03/2017   01:59:16
Cessna 510 / 510-0339 / PHD Interplanetary LLC
AE5DCB   168624      13/03/2017   12:55:17
MV-22B Osprey / D-0279?? / USA - Marine Corps
E4877F   N145WA      22/03/2017   06:41:59
Cessna 208B / 208B1145 / PCALG 208 Leasing Company LLC
(Still using its hex from two registrations ago!)
Paul
Many thanks Paul.  No need for the unallocated as you have found that there are lots flying around with crap hex codes
Morning Ingo, thanks again
Morning Terry, am leaving Beauty Central as is, thanks again
