0 Members and 14 Guests are viewing this topic.
And more...
DLH8FM LH63 EDDG EDDF
DLH4KW LH2447 EKCH EDDM
DLH6TP LH2023 EDDL EDDM
DLH351 LH351 EDDW EDDF
GWI1PU 4U8592 EDDT LEPA
falcon_nl
Nike to be back ;-)
Only i forget 2 planes from yesterday:
48552C, PH-VIR, 121, PIVI, Pipistrel Virus
48557D, PH-DAR, 008, PNR4, Alpi Aviat Pioneer 400
And here you can find the dutch register, becaused they moved to another URL
https://www.ilent.nl/onderwerpen/transport/luchtvaart/luchtvaartuigregister/index.aspx
diddyboy
Hi Alan
Some unknowns from yesterday, and unsure why the AHY is not populating even after doing daily updates.
* 3C526B  QGA411D                                                        2017/04/01 11:06:08
   424293  AHY007   UBBB-EGLL                                             2017/04/01 20:22:08
   424293  AHY008   EGLL-UBBB                                             2017/04/01 22:22:48
* 55E5A4        2017/04/01 10:16:48
Neil
jacobite
#9603
Morning Alan, just a couple for you.
EXS25F           EGPH-LOWS
EXS84G           LIPZ-EGPH
EWG12X         EGPH-EDDM
THY3HS          LTBA-EGPH
Ian (Jacobite)
Afternoon Ingo,
Nothing on your unknowns
Thanks and Sunday has been good so far
I am not adding TUI866 and GMI3326 to the d/b
The majority of AFR short haul routes are alpha numeric, at least the have done away with the AF*** call signs now
thanks again
Many thanks for the route info Ingo.  Those early morning ones are most appreciated
Many thanks flacon, appreciated
Hi Neil
3C526B decodes to D-ADSK, cant find anything on it, noted on a number of logs yesterday
No idea why you cant get 424293 VP-BBR as it is in the d/b.  I believe it had been using a miscode 424272 allocated to BBJ VP-BBK since delivered and was only changed within the last week or so.  Just checked my Navdata and its in there.
No thing on 55E5A4
Afternoon Ian, thanks again
Evening Terry, thanks again
Michel
Alan,
BMS7 LRBC-EGGW
DLH3LR EDDM-EHAM
DLH7CH EHAM-EDDM
EWG3N EDDM-EHAM
EWG4529 GCLP-EDDH
EWG7184 EDDH-EHAM
EWG7406 EDDH-LFPG
EWG8VA GCLP-EDDH
FLI7127 LPPS-EKCH
GWI41G EGLL-EDDH
KLM511 EHAM-GFLL-GLRB
TFL643 EHGG-EHEH-GCLP
Michel
falcon_nl
Here)s the list from today>
484F9D, PH-1493, 29505, AS29, Schleicher ASW 27-18 E
3D420E, D-EXGO, E300, Extra 300L
3E714F, D-KICK, 26085, AS26, Alexander Schleicher ASH-26 E
3E7590, D-KJSI, 54, GLID, Schempp-Hirth Arcus T
3E7924, D-KLBO, 89, DISC, Schempp-Hirth Discus 2cT
3D22BE, D-ELKG, 18-7709056, PA18, Piper PA18-150 Super Cub https://www.jetphotos.com/photo/8160691
3FEF9D, D-MBVG, FDCT, Flight Design CT SupraLight http://www.planepictures.net/v3/search.php?stype=reg&srng=1&srch=D-MBVG
3E7311, D-KITT, VENT, 88/184, Schempp-Hirth Ventus 2cM
44E5B0, OO-YMP, 4548, GLID, Rolladen Schneider LS-4
4850EA, PH-RYN, 1476, BALL, Lindstrand LBL 105A
48DEE4 callsign SPYYE (YAK plane? landing at Stadlohn EDLS)
3ED014 callsign D-KTTK (GLID)
3F0348 callsign D8881 (GLID LS8)
3FF059 callsign DNDUI
