Slight problem with friends Airnav
Started by superspotter, April 12, 2015, 05:22:24 PM
superspotter
My good friend has recently bought an Airnav box and we have encountered a slight problem upon set-up. We have downloaded the most recent version and it works fine but every now and then, the signal drops out and the blue light on the box flashes on and off regularly. Unplugging the box and replugging it in even without shutting Airnav down solves the problem until next time....Any ideas as to the cause?
kind regards clive.
MrParanoia
Try a different USB cable if you/your friend has one spare.  I had the same problem and changing the cable resolved the issue.
Radarbox 3D, GlobeS RTL1090, ModeSMixer2, UBC800XLT, UBC125XLT
Sounds a good suggestion as a first try to cure the issue
superspotter
Sounds like a plan. Im sure he will read this and give it a try.
regards clive.
Kenny
My RB sometime got this problem if I plug portable HDD to the same USB hub.  I think it is USB hub power problem.
Kenny
ANRB 3km north of VTBD
I had problems when using a hub so stopped using it
