Exchanged flight codes
Started by CarlosAbreu, May 07, 2015, 11:18:09 AM
CarlosAbreu
Hi List
I'm with a problema that I can't fix.
There are flight codes in my database that are correct but when I pick up the flight they exchange
For example AFR521L is LPPT-LFPG but it appear as LFPG-LPPT in the interface !!!
I have some flights in this situation, any idea for what's happening ?
Brgds
CA
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
No idea why that might be Carlos, AFR521L shows on the server and on the Navdata as LPPT-LFPG.  Can you advise if that is on myflights and/or the network.
CarlosAbreu
Hi Alan
All flights I pick up here in Portugal that aren“t identified on the server I introduce them manually in my database so I can't understand how they became changed (?) !!!
CA
No idea either Carlos, the one you mentioned is in the d/b and on the server correctly.  I will advise Airnav anyway and see if they can come up with anything.
CarlosAbreu
Ok
Thanks Alan, as far as I remember it happens with other flights from TAP, DLH, BEL, etc...
In some cases I  deleted the entries and introduce again but without any positive result.
CA
Carlos,
Just a thought, but when you have manually changed or entered details in your database, are you remembering to enter 'N' in the auto update column other wise when you update the database it will override anything you have entered with what is on the server.
The server has the correct info anyway Ian
CarlosAbreu
Hi Ian
Can you please inform correct field to aplly "N" in auto update
CA
#8
Carlos,
If you have made a manual update you should place an N in auto-update in the route record and when you update you should use, Do not update manually changed records as your sync option.
CarlosAbreu
I'm going to check procedures, thanks.
CA
CarlosAbreu
Where I can find the auto-update to put the "N" ?
Since I use Radarbox I have manually updated hundreds of data flight and aircraft records and this is the first time I have this kind of problem !!!
CA
Carlos,
Assuming you are using V5.00.72. File/Database Explorer/Tables/Routes you should have a column marked auto update, Y is the default, if you don't want it to be updated replace Y with N.
If you don't use V5 this will not apply.
CarlosAbreu
I'm still using V4.03, so I can't do it !!!
I remember I didn't update because I was going to miss hundreds of data manually inserted.
But due to this kind of problems probably I will do it.
There's any chance to maintain data in the upgrade to V5.00.72 ?
CA
CarlosAbreu
Could you please inform qhere I can get the version V5.00.72 to update my ANRB software.
Thanks.
CA
CarlosAbreu
Never mind, I found it and I'm download it !!!
Thanks anyway, I come back to you if I had problems after instalation.
CA
