Author Topic: Aircraft in Database  (Read 4807 times)
dunc8543
« on: June 06, 2015, 09:12:33 AM »
After a computer meltdown I have been forced to download and install Radarbox on a different PC.
My question is after installation the database is only showing 80,193 aircraft yet on the previous installation I am sure that it showed 250,000.
What is the correct figure I should be looking for please.
Thanks Dunc
Re: Aircraft in Database
« Reply #1 on: June 06, 2015, 09:33:55 AM »
Airframe count is  220k+ airframes.
Have you installed in the program files folder? If yes you should uninstall the software. Manually delete all traces and then install direct to the root folder like C:\AirNav
« Reply #2 on: June 06, 2015, 09:44:27 AM »
Todays DB Update Count:
09:37:46: Update Started.
09:37:46: Checking Server for Updates.
09:37:47: Creating Backup.
09:37:47: Downloading New Database from Server.
09:37:47: New Database Size: 76168 Kbytes.
09:42:06: Processing Downloaded Data.
09:42:10: Creating working database copy...
09:42:12: Processing airports table...100%
09:42:15: Finished processing airports table. Total records: 18480
09:42:15: Processing actype table...100%
09:42:15: Finished processing actype table. Total records: 2569
09:42:15: Processing aircraft table...100%
09:43:07: Finished processing aircraft table. Total records: 230963
09:43:07: Processing airlines table...100%
09:43:08: Finished processing airlines table. Total records: 5550
09:43:08: Processing routes table...100%
09:43:53: Finished processing routes table. Total records: 310769
09:43:54: Update Completed. Restart application
« Reply #3 on: June 06, 2015, 10:17:48 AM »
You will probably have two versions of the Airnav software on the computer.  I would imagine you loaded in off the original disk and then updated to V5.  This being the case the update will have gone to the wrong instance of the software.
The best suggestion is to do what Ingo has stated and delete all traces of both versions and the load V5 straight into somewhere like C:\Airnav
dunc8543
« Reply #4 on: June 08, 2015, 10:43:25 PM »
Thanks Guys
